  • Guests: 37
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Want some RGB LEDs?
Tue Jan 13 2009, 06:57PM Print
Hi all.
Just scored 24 SMD 4mm*4mm LED's on Ebay, ridiculously cheap. For the pair of strips + two drivers worked out less than $40, inc postage.
They have separate anodes and cathodes so the drive circuit can be simplified (as well as a 10F200 being soldered straight on the back in theory)
To remove them you just peel off the silicone, and then hold one side of strip carefully in a pair of hemostats etc and desolder one side, then repeat for the other.
#include "safety_goggles.h"
The driver circuit looks like a PIC uC, possibly a 12C series but is encased in hotmelt.
It could be that they programmed it somehow via the output pins (there is a trick using one diode and a resistor) so it could be reprogrammed by overwriting the existing program code with NOP's and subbing your own.
regards, -A
1231873021 96 FT0 Microled
Wolfram
Wed Jan 14 2009, 08:27AM
Similar RGB LED strips can be gotten cheaper from DX: Link2 and Link2 .
Avi
Wed Jan 14 2009, 04:46PM
yay! SMD RGB LEDs!
although quite expensive, also 4mm does not seem very SMDish :(
Wed Jan 14 2009, 08:23PM
well 4mm is a lot better than trying to sand down 3mm LED's. Also these are eye-stabbingly bright for their size at 30mA, more like Luxeons.
Height is only 1mm :)
-A
