  • Guests: 96
Inducktion (32)
Standa (31)
nabzim (33)
12/23 David (39)
12/25 Kolas (18)
Wire position on rails of a railgun?
Cwazy
Mon Jan 12 2009, 06:40AM Print
Cwazy Registered Member #1106 Joined: Thu Nov 08 2007, 01:15AM
I was wondering if the wire position on the rails of the railgun affect the direction of the lorenz forces?
On the railgun that I am currently working on, which is pneumatically injected, the wires that go from rails to capacitors, are currently attached about 1" into the beginning of the rail. Does that mean that when the projectile is initially injected into the rails to close the curcuit, the projectile will actually fire backwards?
for a really lame picture,..,.,.,
============Z= -
the z indicates where the wires are attached and the - is the initial position of the projectile. it is suppose to be shot to the left. /obviously/
Advice is greatly appreciated
Thanks
-Cwazy
PYLEMET-mk2
Tue Jan 13 2009, 11:52AM
PYLEMET-mk2 Registered Member #1513 Joined: Sat May 31 2008, 12:08PM
yes, projectile will fire backwards :)
also if wires connect to rails lower than projectile level, projectile will fire up :)
