  • Guests: 49
Wizzup (30)
12/09 Killa-X (34)
12/09 Luca (45)
12/10 davovinch (75)
High voltage pulses
terspolarma
Sun Jan 11 2009, 10:17PM Print
terspolarma Registered Member #1925 Joined: Sun Jan 11 2009, 10:10PM
I am planning to make a power supply with hv output pulses. Peak value is 30 kv and the pulse width will be short. Frequency will be low and adjustable(0 to 20~25 Hz).
How can i realize this project?
Sun Jan 11 2009, 10:18PM
Marx generator
Hon1nbo
Mon Jan 12 2009, 03:21AM
capacitor pulse into an ignition coil should work... and, IIRC, the result should be nowhere near square wave as once the current/voltage rise peaks the transformer will not function until it changes direction, as a constant current cannot induce a current in a secondary winding except for the rise time from the moment it is connected...
Mon Jan 12 2009, 06:30AM
You don't say what the output impedance of your device should be, so if your application will accept a high impedance, why not make a multivibrator with two EHT shunt triodes like PD500 - then you will have a square wave whose duty cycle you can vary very easily.
Thomas F
Mon Jan 12 2009, 06:59PM
Thomas F Registered Member #503 Joined: Sun Nov 19 2006, 06:37PM
Hi ,
You can use a uC to generate the pulses and feed it to a MOSFET,through a MOSFET driver.Give huge flexibility,esp if you want to do other stuff too.I had used a PIC with a ceramic resonator (455kHz ) to realize the low frequencies.
The transformer was a CRGO UU core,with an air gap on both legs of about 2 cellotapes thick.Use very low duty cycles of about 10%. As the frequency goes lower,duty cycle goes higher and gap is increased, the voltage increases,atleast for my txfer.
A ferrite txfer would probably not work at these low frequencies,maybe the experienced guys here could tell why !!
Good luck.
Thomas
big5824
Mon Jan 12 2009, 09:28PM
you could modulate a flyback to those low frequencys then maybes smooth it a bit or something, could that work?
terspolarma
Tue Jan 13 2009, 11:34AM
I am thinking something like this:
Dave47
Tue Jan 13 2009, 01:32PM
Dave47 Registered Member #84 Joined: Thu Feb 09 2006, 01:06PM
Slightly OT...
I still have the original Radio Electronics magazine with all of those projects in it. It was a special issue.
David
Tue Jan 13 2009, 06:52PM
Have you considered ignition coils? They're cheap, readily available, and run at low frequency. Your target output voltage isn't a problem either.
Tue Jan 13 2009, 07:22PM
terspolarma wrote ...
You're missing a lot of requirements here. Please specify what they are so we can better answer your question:
1. Pulsewidth?
2. Risetime / Falltime
3. Duty Cycle (or PRF)
4. Load Impedance your driving into
5. Pulse-to-Pulse regulation
6. Pulse Variability (variation on top of the pulse - do you want a clean pulse, or don't care if it rings with several kV amplitudes)
7. Allowable Pulse Droop (relates to 6 above)
