  • Guests: 29
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
spoils from a hamfest...
Hon1nbo
Sun Jan 11 2009, 03:58PM Print
ok, so yesterday was the second day of the cowtown hamfest in Fort Worth, and I ended up buying some new toys to play with (such as a kenwood tribander, and a phone patch
but also, I got a LOT of stuff for free, since no one wanted to carry them out with them, and they were "as-is"... so I used a dolley to get them to my car...
after giving most of the surfaces a good clean (so my mom would not freak out), I decided to plug the tube-based General Electric Sweep Generator (which was a freebie) into my oscilloscope and fire it up... and it still works great!!
so now i am wondering what number of things I could/should do with this large, old, but useful piece of hardware... and hope fully find someone here who might have information on the thing, as I did not find much online...
I will try to get the tubes out safely to see what they are... but since I have no experience pulling out a tube from something like this, I fear I will break it...
EDIT: I forgot to ask, since the sweep generator has a metal case, and uses a two prong cord, should I replace the power cord with a three prong, with the ground prong connected to the case?
Myke
Sun Jan 11 2009, 08:09PM
Tubes are not all that easy to break when pulling them out. Just pull them strait out from their sockets. If they are hard to pull out then have something over your hand when pulling it out so the tube doesn't go flying.
For the metal case, first check to see if the case is floating above ground with a low wattage 120V lamp. If it lights up then that means there is a short to the case so you should open it to see where the short is. If it doesn't light then you can ground the case.
Tue Jan 13 2009, 06:22PM
Why take it apart? tongue Just because it is old doesen't mean it is no good. For certain (audio etc) applications valve equipment is fine and also is virtually indestructible under uhm, high RF field conditions.
Regards, -A
Hon1nbo
Tue Jan 13 2009, 10:51PM
Conundrum wrote ...
Regards, -A
who said anything about dismantling it? You cant see the tube names from without taking them out... in this case, which I have yet to get around to tongue
Wed Jan 14 2009, 12:08AM
You don't say what sort of sweep generator it is. Many were designed chiefly for aligning IF transformers in superhets - 465kHz and so on. Others are more ambitious.
