  • Guests: 67
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
24VDC@5A from a PSU?
phinsil6
Sat Jan 10 2009, 12:52AM Print
phinsil6 Registered Member #1914 Joined: Wed Jan 07 2009, 06:50PM
Does anybody know if there is a way to get 24VDC@5A from a regular computer PSU? Any help would be greatly appreciated.
aonomus
Sat Jan 10 2009, 01:33AM
Short of completely opening it up and fiddling with the pins on the TL494 to change the PWM, I'd just get 2 cheap PSU's and series the 0-12V segments, because the -12V rail has only tens or hundreds of mA, while the +12V rail always has 10's of amps.
Keep in mind that computer PSU's have short circuit protection, if you apply a low-resistance load too quickly it might decide that its a short and simply shut down gracefully (ie: without asplosions).
phinsil6
Sat Jan 10 2009, 02:42AM
so what you are saying is that i should get two cheap power supplies and series two of the 4pin molex's to get 24VDC? that makes sense, but how do i make sure i dont pull any more than 5A?
aonomus
Sat Jan 10 2009, 03:52AM
Well what you'd want to do is mod the PSU so you have binding posts instead of the 24 pin connector so you can just plug everything together with jumpers.
As for current limiting, you can use mosfets to do a current limited power supply.
El_Roberto
Sat Jan 10 2009, 05:31AM
El_Roberto Registered Member #1774 Joined: Wed Oct 22 2008, 02:51AM
Adding them in series doesn't work, I tried, It just short circuits the powersupplies...
phinsil6
Sat Jan 10 2009, 06:29AM
thats a good point, just putting any copper on the pins would short circuit the psu...do you have any other ideas then?
El_Roberto
Sat Jan 10 2009, 08:11AM
Boost converter? If you dont want to make one Im sure you could buy a good 12v to 24v 5amp one for fairly cheap
phinsil6
Sat Jan 10 2009, 03:46PM
actually im already making one, heres the schematic. but it needs a 24VDC power source
aonomus
Sat Jan 10 2009, 06:10PM
Well it must vary on the power supplies El Roberto because I've seriesed a few of them...
Bjørn
Sun Jan 11 2009, 06:45AM
If there is a common ground there will be a short circuit since the ground level on one PSU will end up at 12V.
