  • Guests: 56
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
A quick way to wire a good quality coil
lhl_henrylui
Wed Jan 07 2009, 12:00PM Print
lhl_henrylui Registered Member #1498 Joined: Thu May 22 2008, 07:08AM
Anyone have a quick way to wire a good quality coil?I found it difficult of wiring a coil.
Any idea are welcome!
Wed Jan 07 2009, 01:30PM
Good quality comes from taking the time to either wind it by hand or build a lathe like rig to mount the secondary form in.
I only do my coils by hand as I got 100% control, takes some time, just remember to put tape on already done parts and then varnish it as soon as its done, keep it in a room with a constant temperature to avoid windings suddenly falling off if the temperature rises.
You are also posting alot of threads that could be avoided if you did some research on some of the many sites you can find via. f.ex. google. :)
Wed Jan 07 2009, 05:58PM
Assuming you're asking about a TC secondary
it's worth making a simple rig to rotate the coil with it's axis horizontal
you can turn it by hand or motor for winding.
The benefit of making a rig is that when you varnish the coil
you can keep it rotating to get a lovely smooth finish
so a motor driven winder is best.
You can use ac or dc drill, electric screwdriver etc. etc.
coillah
Wed Jan 07 2009, 06:22PM
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
GOOGLE IT! DAMN!
rp181
Wed Jan 07 2009, 07:13PM
That's kinda hard to get results on. It all depends on the size of what you wind. Anything past 2 feet long and it would be worth it to build a winding jig.
