  • Guests: 30
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Ferrite Transformer Design
Firefox
Wed Jan 07 2009, 08:12AM Print
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
I'm working on Uzzors' SMPS Link2 and have hit a small roadblock in construction. While testing, I was using a 3 ohm resistor as a load, which should give a load within the limits of what the supply can handle. However, I was only able to get 130W (20V @ 6.6A) at maximum power setting. Fairly quickly the transformer insulation melted and blew my mains fuse (hopefully not my IRFP250s). I was using an old monitor flyback core with a 130mm^2 cross section. My windings were 20AWG (.8mm) PVC insulated wire for both my primary and secondary.
Well, now that I know that doesn't work, what exactly do I need to do to make sure that this core can provide the 750W that I want it to, or should I consider buying a new core? Also, all of my components are good for 1200W+, but it was suggested on the HV chat that a flyback core is only going to be good for 6-700W. If I wanted to get a new core to up the power, what would I be looking for, and where (in the USA).
Wed Jan 07 2009, 10:36AM
The resistance of the wires, even if only 0.5 ohms can drop a decent amount of voltage. Now the DC resistance might seem low, but remember that the skin effect kicks in too, increasing the effective AC resistance. At 45kHz, for 16A capable wire I would use four strands of 22AWG twisted together as litz wire. The primary only has to handle about 4-5A at full load so bifilar 22AWG should be enough. What limits power in transformers is how much power they can dissipate. A core can lose power through losses tied to drive frequency and/or magnetic flux being too high, but that's about it unless I'm mistaken. The other losses are copper losses from the windings, and ideally you want to fill the entire window area with copper to reduce the resistance as much as possible. So if you can the required number of turns in at the required thickness in the winding area, the core is large enough.
EDIT: I guess this should be copied onto my site as well.
Firefox
Wed Jan 07 2009, 09:33PM
Hmmm, thanks Uzzors. I've got some 20 and 26AWG that I can wind into multifilar wire. I'm probably going to end up needing to get some magnet wire or a bigger core eventually.
Wed Jan 07 2009, 09:47PM
Firefox wrote ...
Regarding our chat the other night, I looked more into which cores there are to get at retailers, and the best buck for the money are some > 1kW ferrite kits from RS components, they are around 30 euro for the N27 material kit, 840mm^2 crosssection and 45 euro for a N87 material. Link2
I haven't really found anything good at ebay, ham sites, other auction sites etc, just have to find large smps and salvage big ferrites :/
Firefox
Thu Jan 08 2009, 04:58AM
Ugh. This just isn't going to happen with this tiny core. With a core cross section of 125mm^2 and a winding window of 500mm^2, I just can't fit all the copper and insulation I need onto the transformer... time to go looking for a new one, I guess.
Thu Jan 08 2009, 11:02AM
I managed to get 60 windings of 2x AWG24 on for the primary and the 2x 25 windings for the secondary, each of the 25 consists also of 2x AWG24, its also way too small to handle what the 460s FET can put out :)
But it will be fine for testing while I figure some washers for that big core.
Firefox
Fri Jan 09 2009, 02:54AM
Yep. Good luck, MadsKaizer. My testing is done, so I just need to find that core. Mayhaps I'll find a similar flyback core. If so, I'm just going to put the square sections back to back and make it an EE core to hopefully get the power I need.
