  • Guests: 79
Skywarrior (52)
Dark Horse (54)
LD LANGER (38)
12/19 kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
3 Phase HVDC supply with MOTs
1 2 3 4
Kizmo
Tue Jan 06 2009, 11:48PM Print
Im slowly putting together maybe largest MOT powered TC ever made. Since where i live (Finland) its not proper way to load power distribution network by putting huge pile of transformers in one phase only. 3ph power can be found almost any place here, even summer cottages may have 3~ service so why not use it with TC? 400V phase to phase and 230V N-L @ 50Hz.
Basic idea is to build rectified 3ph MOT stack and then use DC Resonant charging toplogy. I have harvested MOTs for about year now and i have torn apart more than hundred ovens so far. For this project i will use 3 + 3 identical transformers rated 2100VAC .85amp and 2300VAC 0.65amp. Each phase will have 2 mots in antiparallel, primary and secondary windings are connected in star configuration. Secondary star point is connected to mains ground.
First setup is here: (THIS IS ONLY PROOF OF CONCEPT PROTOTYPE. FINISHED DEVICE WILL BE SAFER AND BETTER)
1231284905 599 FT0 3phsystem
1231284925 599 FT0 3phladder
Youtube clip: Link2
Then i made quickndirty 6-pulse HV rectifier from 24 microwave oven diodes and results were spectacular!! (remember, nothing is resonating here, no capacitor involved)
Youtube clip: Link2
It sounds really weird, input power was around 8kW and output voltage 8kVDC. My ballasts (3 identical mots left in first picture) were toasting really badly after 15min of use. Transformer bank itself was barely warm to hand.
Line voltage without load: 234VAC
Line voltage with load: 233VAC
Voltage after ballast withoud load: 190VAC
Voltage after ballast with load: 109VAC cheesey
You dont need to be very smart to see what makes those poor ballasts toast so badly. I really need to wind my own adjustable ballasts which can take serius beating. I think i can push these well over 10kVA without much trouble. Im planning to submerge all transformers and rectifier in oil just for cooling purposes. I have already nice tank with wheels :)
GeordieBoy
Thu Jan 08 2009, 04:02PM
The 300Hz tone that you can hear in the second video is because it is using a 6-pulse rectifier. The DC output has a significant AC ripple component at 6 times the line frequency ie. 300Hz
DC also arcs better than AC because in the case of the 6-pulse rectifier the output voltage never falls right down to zero beetween the mains peaks. Arcs are generally more stable because, unlike AC there are no current zeros for the arc to cool and extinguish.
-Richie,
Alexandre
Thu Jan 08 2009, 04:17PM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
NICE!amazed
Kizmo
Thu Jan 08 2009, 04:43PM
GeordieBoy wrote ...
..DC also arcs better than AC because in the case of the 6-pulse rectifier the output voltage never falls right down to zero beetween the mains peaks. Arcs are generally more stable because, unlike AC there are no current zeros for the arc to cool and extinguish.
-Richie,
Yep and there is 3 times the power of a single 2mot pack. One strange thing i noticed was that it was extremely hard to get jacobs ladders work with DC. It was almost impossible and every time arc got stuck it melted 3mm steel rods and whole thing collapsed cheesey
I will make new ballasts soon so we will see some +10kVA DC action! And then some oil cooling and +15kVA... :)
Thu Jan 08 2009, 05:03PM
Kizmo wrote ...
...And then add some resonant caps! cheesey Link2 This was with JUST 3 caps per 2 MOTs, imagine using 4-6 caps!!! 3 meter arcs anyone? suprised
Kizmo
Thu Jan 15 2009, 03:25PM
Update 15.1.2009
When im buying beer for myself i usually go for 12pack instead of 6pack. Looks like same thing applies here as well:
1232032661 599 FT61486 Johdotettu
12 MOTs, each rated at least 1.3kVA
1232032661 599 FT61486 10kva
Test run @ 10kVA, transformers didnt even get warm! Everything except ballasts were stone cold.
1232032661 599 FT61486 Kontrolleri
And here is control panel, i got the case from local cemetary (old fuse/main switch box from early 60s)
Next step is to mount all transformers in steel tank and finish extrenal wiring + ballasts.
Link2 Small video about near 10kVA run (did some fine tuning & real measurements)
Thu Jan 15 2009, 03:38PM
Kizmo wrote ...
Update 15.1.2009
How much do you dare to depress me tongue
Firefox
Sat Jan 24 2009, 02:17AM
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
Since our latest posts have been wiped by some jerkball's dead worm, let me reiterate: Awesome! Now I double dare you to take all those MOCs and MODs and make a three phase CW multiplier for your MOT stack. cheesey
Hazmatt_(The Underdog)
Sat Jan 24 2009, 08:41AM
I'd like to see some proper HV wire on this project or maybe just some RG8X without the shield, and finished off with 3 large beehive bushings.
I like to see things over done, but I get worried about over-KILL sometimes, if you know what I mean.
Kizmo
Sat Jan 24 2009, 11:16AM
When it comes to finished product safety is my number one concern. I have bought some proper 10kV high tension wire for internal wiring. Whole thing will be installed in steel tank and submerged in transformer oil including rectifier bridge so this device outputs HVDC only. And i bought few ceramic HV feed through insulators too.
Maybe i put together another 3 phase stack to test resonant capacitors and voltage multipliers :)
