  • Guests: 53
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
Whitelight Argon/Krypton Laser Melles Griot 643
kilovolt
Mon Apr 27 2009, 05:41PM Print
kilovolt Registered Member #2018 Joined: Tue Mar 10 2009, 09:56AM
Last week I bought a used argon/krypton-laserhead without power supply for euro 36 (which is very cheap in my opinion smile ) on ebay. Unfortunately I had no specifications or other data like pinouts for this tube. So I had to scrounge the internet but there was not very much information about this particular laser head (it is similar to the omnichrome 643).
After some research I've found out the pinouts (with simple continuity tests smile ) and the most important data about the tube (tube-voltage about 180VDC @ 3.5 to 14A, filament power 3V @ 25A, igniter is powered from anode voltage). After that I made some modifications to power this head with my selfmade argon-laser-power-supply for the ALC-60 head.
Here are some first pictures:
The Melles Griot 643 head in comparison with an American Laser Corporation ALC-60 head:
Groessenvergleichu
Power connectors of the head:
Anschluesse
Frontside:
Strahlaustritt
Whole unit:
Gesamtansicht
The opened laser-head:
Laseroffen2
Detail1w
Detail2
Dsc00007yik
And some pics from the powered unit:
White beam splitted up with a grating:
Dsc00036izm
Beam at 7A tube current, 6 blue lines, one yellow (seems like green on the photo) and a red one:
Dsc00040lan
Dsc00041qdy
Greets kilovolt wink
Mon Apr 27 2009, 06:19PM
Wow that is awesome! And for $50! amazed Do you know how much power it is putting out?
kilovolt
Mon Apr 27 2009, 07:16PM
Thank you for your kind feedback ... wink
Unfortunately I'm not able to measure the output power (no power measurement equipment). I would estimate the output power between 100 and 150mW, depending on the tube current. The tube seems not to be in a very good condition, but it works (red line is a bit weak, which is a sign for low pressure).
Now I have to rebuild my argon-laser-power-supply more definitively to power both lasers, the ALC-60X and the Melles Griot 643. It should be somewhat universal applicable, so I think I will build it with a selector to choose which laser head should be powered.
Greets kilovolt
Tue Apr 28 2009, 10:18PM
Very impressive! Your pictures are more than 400 pixels wide, but since they're so cool I will leave them alone :)
kilovolt
Wed Apr 29 2009, 07:07PM
Thank you very much for your exception, Steve!
Next time I will post the pictures smaller.
Best regards kilovolt wink
