  • Guests: 31
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Peak current limiting in flyback inverter
Sat Jan 03 2009, 08:56PM Print
I am building a flyback inverter for TV transformer. I want to have a potentiometer which sets maximum pulse width ("power control"), but also a feedback from an emitter current-sense resistor which will limit the pulse width when the peak current is too high (e.g. a short-circuit on the xfmr output).
Now I want to use a SG3525 ( Link2 ) SMPS controller but I have no idea how to set it up. It has an error amp, I know how would I set it just to limit the peak current, but I have no idea how to incorporate the power control... Maybe I should use another controller?
Thanks for any help smile
Sat Jan 03 2009, 09:53PM
You set your reference at the inverting input, as well as a gain setting R or RC network. Try simply shorting compensation to the inverting output to start with. Current feedback goes to the non-inverting input, and should equal the reference at the desired peak point. It might be the other way around with the SG3525, I've only used the TL494. Check this circuit for reference. Link2
Sun Jan 04 2009, 09:28AM
I'm not sure about one thing. They say that the Pin 9 has a pull-up current source, but according to the schematic there's a pull-down source. Is there an error in the datasheet?
1231061300 152 FT61120 Pwm
Sun Jan 04 2009, 01:31PM
Uzzors wrote ...
Yeah, but the problem is that the current will be limited to a different value dependent on the "power" setting. I want it to always limit to the same value, the power control sets only maximum allowed pulse width.
IIRC the tl494 has two error amps, so it should be easier. I'll take a look at the datasheet (though I will need a gate driver as the tl494 outputs are not totem-pole).
EDIT: How to set the gain of tl494's op amps? They contain a diode on the outputs...
Sun Jan 04 2009, 07:01PM
Right, I forgot about that. You'll need a TL494 or some other chip with two comparators. I've never thought about the diodes, and they don't seem to have caused problems. Getting the right gain and loop compensation is so complex that it's best left for people who do it for a living. For your needs max gain would work alright since you're just setting the maximum duty cycle which will need to trip instantaneously. Compensation is only needed when stabilizing a control loop.
GeordieBoy
Sun Jan 04 2009, 10:40PM
UC3845 is the chip you want to be using for a flyback converter. It has the necessary internals to control the average power throughput, and also a fast over-current shutdown to set an absolute limit on peak current through the switch. This chip is found in most cheap offline switchmode power supplies below 70W where the flyback topology dominates.
It works just as you described. Current mode control effectively varies the duty cycle to control power throughput and keep the output voltage in regulation during normal operation. If the output is short-circuited, the current waveform becomes continuous, and the fast peak-current limiter kicks in to prevent the current integrating up to a destructive level. It is this action under s/circuit conditions that often leads to cycle-skipping and the familiar squeal from flyback converters.
-Richie,
PS. All the best for 2009 to everyone on here.
