  • Guests: 48
What type of fun do ignition coils have?
1 2 3 4
Killa-X
Fri Jan 02 2009, 04:24PM Print
I was thinking of getting a $15 ignition coil and using a 12V driver to power it. I just wanted to know what things you can do with these ignition coils? A friend of mine in a messenger said he show his boss and he (boss) lit his cigar on the spark gap, and then later he connected a 37 inch jacob ladder to it and manage to get 6-8 inch spark arches.
But what other fun can these bring you?
Circuit Im using: Link2
Buying from: Link2
Fri Jan 02 2009, 04:40PM
Killa-X wrote ...
This is absolutely unrealistic if you want your coil to last more than a few seconds. 2-3" sparks are possible, but not "white plasma" (as with continuous, hot power arcs). Maybe 2" but the coil may run hot.
Killa-X
Fri Jan 02 2009, 08:34PM
Ya but mind the power output is around 40,000 volts and very fined tuned for adjustable spark gaps.. I know a 1cm spark isnt hard at all of due to the power output but still. lol
Fri Jan 02 2009, 09:01PM
that poor 2n3055 is going to vaporize before you get that kind of performance out of your ignition coil :)
Perhaps take a look a this thread, but mind you its using mains voltage. Link2
MOT_man
Sat Jan 03 2009, 03:51AM
Hey hey hey .... guys you can make a power supply very easily with an ignition coil, 600 watt dimmer switch and a 10 uF 330 V motor run cap. I used one at 120 V input to a car ignition coil and produced a 50 kV power sourced. Heck I've done 2 in series for 100 kV.
I can send schematics via email if you like. Very easy build. This device can light a cigar very easily!!!
Myke
Sat Jan 03 2009, 06:53AM
In series? I think antiparallel would make twice the voltage.
I have made that circuit before and it keeps tripping my GFI prtection outlet when I turn it off. I used a RFI filter on the mains and it stopped the iggy coil from tripping the GFI.
The circuit is just the dimmer, cap, and iggy coil all in series.
EDIT: In series, the iggys will only see 60V each. So the total voltage between the outputs would be 50kV.
MOT_man
Sat Jan 03 2009, 07:28AM
The coils are both fed off the 120V circuit. The outputs of both coils produce 50 kV - when arced together they will produce 100 kV.
3l3ctrici7y
Sat Jan 03 2009, 08:16AM
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
MOT_man;
Could you post the schematic?
Berni
Sat Jan 03 2009, 09:14AM
Berni Registered Member #1132 Joined: Mon Nov 19 2007, 06:15PM
Well white hot arcs are completely possible with a ignition coil. I driven a ignition coil with a IGBT H-bridge running off recfitifed mains ( we have 240V mains so rectified its around 300V) But in the end the coil arced over internally to the can and then the can arced to the terminals setting my varnish on fire (That i used to insulate from arcovers on the outside)
So yeah its no way reliable driving a ignition coil at these ridiculous powers.Old flybacks are more up to the job but they can also fail when driven relay hard.
For the highest powers you need to get the biggest ferite core you can get your hands on, make your own HF transformer and dunk it in oil. Or get a pole pig
Sat Jan 03 2009, 11:02AM
If you place a piece of photographic film between the electrodes, and fire a single spark through it, you will find, when you develop it, a complex fractal-like pattern extending centiemetres away from the spark impact point - a superb way of illustrating that there is often a lot more to an electric discharge than can be seen with the naked eye.
