  • Guests: 55
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Power Supply Smoothing
Marauder709
Thu Jan 01 2009, 09:39PM Print
Marauder709 Registered Member #1895 Joined: Thu Jan 01 2009, 03:12AM
I have a stepped up 1500 VAC output. I have the circuit on a bridge diode however, I'm having trouble finding the right capacitor to smooth the current wave.
Is there a formula that I can use to find the appropriate capacitance and voltage to smooth the output?
badastronaut
Thu Jan 01 2009, 09:53PM
badastronaut Registered Member #222 Joined: Mon Feb 20 2006, 05:49PM
It depends on how much you want to smooth the supply. You need a ripple specification. You can't practically have nearly pure DC with just a cap.
Marauder709
Thu Jan 01 2009, 10:11PM
I'm shooting for 40-50 V or so.
LithiumLord
Thu Jan 01 2009, 11:01PM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
All depends on the current ;)
Billybobjoe
Thu Jan 01 2009, 11:03PM
Link2 - should tell you all you need to know.
Thu Jan 01 2009, 11:07PM
You need to know what the load is as well. The load and filter capacitor have an RC time constant, and depending on the desired ripple which is better expressed as a percent of the supply voltage, you can find the maximum time between filter "charges" aka the frequency of your AC source. This is backwards from what you want of course, you'll need to look up the formula and rearrange it yourself. First find the discharge %, then with the frequency you find the time constant, and finally determine the size of C required with a given R to get the discharge % desired.
EDIT: Beat by two posts! Billybobjoe's method is much simpler.
Marauder709
Thu Jan 01 2009, 11:12PM
thanks much all
Thu Jan 01 2009, 11:40PM
A rough rule which usually produces good results is that a minimum of 10,000uF per amp will smooth a 50Hz supply sufficiently for most practical purposes.
