  • Guests: 71
Optical switching/triggering (for a novice)
mogallin
Sat Dec 27 2008, 10:12PM Print
mogallin Registered Member #1883 Joined: Thu Dec 25 2008, 01:58PM
rp181 said in another post that optical switching was simple. Not simple enough im afraid since i havent got the slightest idea how the different components he mentioned works,or what they do... (these are the components he mentioned: "LM339 IC, 2 resistors, and the photodetectors")
...except for the resistors maybe :)
Could someone mybe explain what they do or how they are used?
And maybe even how to put them together to form this nice little optical trigger?
badastronaut
Sat Dec 27 2008, 10:23PM
badastronaut Registered Member #222 Joined: Mon Feb 20 2006, 05:49PM
Have you read the datasheet for the devices? Wikipedia on photodetector will get you some info on how to use one.
mogallin
Sat Dec 27 2008, 10:38PM
Thanks, I'll check there!
(Sometimes i feel so dumb. I've been so busy checking coilgunsites that i forgot old dear wikipedia...)
rp181
Sun Dec 28 2008, 12:41AM
sorry i didnt get the stuff of on my site, the server went down and i burned a couple of IC's due to bad insulation on a jumper. LM339 is a comparator. It takes two voltages and "compares" them. Depending on this, the output goes high or low. Photodetectors vary there resistance based on the amount of light. ile get it up tomorrow
El_Roberto
Sun Dec 28 2008, 03:37AM
El_Roberto Registered Member #1774 Joined: Wed Oct 22 2008, 02:51AM
About how fast can this work upto? Because I was originally going to use a microprocesor but I think it might be easier to go with this, I expect it the round to be going faster than about 50m/s
mogallin
Sun Dec 28 2008, 09:38AM
Thanks once again.
El_Roberto to somewhat answer your question killah573 wrote this in another thread
( Link2 )
"Like rp181 said, you should use a phototransistor (or a photodiode). A photocell is simply too slow, especially when you build higher power, higher speed coilguns. A phototransistor should be fast enough for most applications, but the fastest coilguns will need the even-faster photodiode."
rp181
Sun Dec 28 2008, 04:54PM
Here, look at the "4 detector circuit". This is the basic thing.
The one im doing uses additional IC's, as i wanted to have a programmable delay for fine tuning.
mogallin
Tue Dec 30 2008, 07:01PM
ive been looking around for suitable diodes and comparators. Would there be any important differences between a DIL and a SO comparator? Guess these things mean something to someone with a bit of kowledge about this sort of things...
btw thanks for the nice link rp181
rp181
Tue Dec 30 2008, 07:47PM
I think those are packages. Make sure its not SMD unless you can use those.
EDIT: looked it up. DIL is the one you want. SO is a surface mount package.
mogallin
Tue Dec 30 2008, 09:19PM
ok, thanks.
I think this will be all help i need, at least for the optical switches.
