  • Guests: 59
Engineering Problem
skmetal7
Wed Mar 29 2006, 05:43AM Print
skmetal7 Registered Member #101 Joined: Thu Feb 09 2006, 08:12PM
Ok, so i got a homework assignment today. I need to find the friction force in a syringe(rubber against plastic). The plunger is pushed with the end of the syring sealed off, the internal pressure pushes back on the plunger. The initial volume is 6cc, then, when let go, it moves back to (an average of) 5.24cc. I calculated the change in volume and converted it to in^3, that is .046in^3
The plunger diameter is 1/2"; the change in volume is 0.046in^3 (6cc to 5.24cc); atmospheric pressure is 14.7psi; inital volume is 0.366in^3 (6cc). apparently that is all I ineed to know. The only friction formula that i knon is F=uN (u=coefficient of friction, N is force normal) how do find force normal in a cylinder? i think the coef. of fric. of rubber is between .5 and .85
its probably something really simple im looking over
Bored Chemist
Wed Mar 29 2006, 05:52AM
The gas in the syringe has been compressed to a smaller volume so its pressure will have risen. That pressure is pushing the piston out.Friction is holding it back so the friction force must balance the product of the overpressure and the area.
skmetal7
Wed Mar 29 2006, 06:04AM
so F=PA?
I calculated that it takes 3.32 lb to push in the plunger. do i use that as P?
Wed Mar 29 2006, 06:25AM
I haven't been taught anything even remotely like that, but here is how I would do it...
force exerted by piston=force exerted by friction
force on the piston = pressure* area, so by boyle's law we know P1*V1=P2V2 or 14.7*6=P2*5.24 P2=16.83psia, so deltaP=16.83-14.7=2.13psi. The area is A=3.14*(D/2)^2 A=0.196 in^2, so force (lbs) = 2.13psi*.196in^2=0.418lbs=1.85N
From there I am going in the dark, but I am assuming that you want to solve for F, so F=coefficient of friction of the syringe and N the force exerted on the plunger (in whatever unit you professor wants the F value in, lbs/N/whatever)
edit, where did you get 3lbs?
And looking at some articles on the internet, it looks like you can say that the answer is the .418lbs that I calculated (or whatever you got) as teh answer smile Normally it is equal to the weight of the oject? I don't know
skmetal7
Wed Mar 29 2006, 07:02AM
3.32 lb was calculated from this equation: Fh=Ap[(P1V1/V1-APX) - P1] which is derived form other statics equations dead
yeah i got .423lb, so it doesnt smell fishey or anything
