  • Guests: 32
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
MOSFETs in parallel?
Camel
Thu Dec 18 2008, 08:41AM Print
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
Hi,
Is it possible to run MOSFETs in parallel? I'm trying to make a high power boost converter, the largest MOSFETs I have are rated 900V 7A. I'm need one rated 800V 15 amps, at least.
I've bid on some 1000V 50amp IGBTs on ebay, but if I don't win them it would be nice to know I if I could use these MOSFETs instead.
I plan on driving the gate with a 555. The 555 will be run at 12V.
Cheers
Dr. Slack
Thu Dec 18 2008, 11:55AM
Yes, but with "buts". See the wiki.
Camel
Thu Dec 18 2008, 12:11PM
The MOSFET page on the wiki doesn't really have anything about running them in parallel. :S
Thu Dec 18 2008, 01:00PM
I use paralleled mosfets at the rated current of a single in my induction heater without problems. However trying to push more current through them than a single mosfet is rated for doesn't work well, and you're better to parallel them to reduce power dissipation instead.
Thu Dec 18 2008, 01:02PM
Mosfets to be run in parallel having the same part number but from different manufacturers should be avoided, as they will have different mask designs, which may result in small - but significant - differences in turn on delay time. (The mosfet with the shortest turn-on delay and quickest rise-time will hog most of the current) So choose mosfets from the same manufacturer - and from the same batch if possible - for best results in parallel operation.
Dr. Slack
Thu Dec 18 2008, 01:41PM
Sorry, my bad, not linked, try again.
Thu Dec 18 2008, 09:36PM
Further to my comments about turn-on time, parallel MOSFETs must be mounted close together so that their gate drive impedances are as near the same as can be managed in practice, and all devices switch simultaneously.
I've often thought that some of the unexpected effects and malfunctions reported on this forum may be due to undiagnosed parasitic oscillation of multiple devices, a problem address in this paper below:
Eliminating Parasitic Oscillation between Parallel MOSFETs
There's really nothing complicated about it, and no reason why you shouldn't do it with a minimum of fuss. It's a common enough circuit configuration.
