  • Guests: 58
Plasma Cannon?
cduma
Wed Dec 17 2008, 05:43PM Print
I have heard that if you run several (hv) dozen kJ through a small piece of aluminum inside a potatoe cannon (Minus propellant) that it will launch the spud. I have a 45uF 35kV bank and may want to try this.
El_Roberto
Wed Dec 17 2008, 07:13PM
El_Roberto Registered Member #1774 Joined: Wed Oct 22 2008, 02:51AM
Yes It probably would launch it but I doubt it would launch it very well, I think with that bank you would be better off making something like a railgun.
Hon1nbo
Wed Dec 17 2008, 08:15PM
such propulsion has been discussed her, and the results are impressive, but not spud gun impressive... they are called ElectroThermal Guns... (currently I am at a loss of which thread had the actual details of one, but I am sure you can find it easily)
rp181
Wed Dec 17 2008, 09:42PM
Not impressive? : Link2 Larda is Larse on this forum.
guitardude012
Wed Dec 17 2008, 11:47PM
guitardude012 Registered Member #968 Joined: Fri Aug 24 2007, 04:54PM
That ETG is amazing. I think what DaJJHman meant by "not that impressive" is that it is being compared to launching potatoes for hundreds of yards or through cinder blocks using only some pvc pipe, hair spray , and a grill lighter.
rp181
Thu Dec 18 2008, 12:00AM
ETG's are quite good, effeciancies of 50% can easily be reached. ETC (electrothermal chemical) increase power alot. ETC's use a explosive instead of metal powder. On that forum i posted a link to, a person is making a ETC using Acetone peroxide as the propellant. High speeds are expected because the shock wave will serve to push the projectile more than the pressure.
Kizmo
Thu Dec 18 2008, 01:43AM
Sound wery safe
Organinc peroxides and high voltage-high energy electricity :D
rp181
Thu Dec 18 2008, 02:05AM
It's as safe as you make it :D
Camel
Thu Dec 18 2008, 02:23AM
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
I hope he stands well back . . .
El_Roberto
Thu Dec 18 2008, 03:41AM
Damn just been looking at the link posted above, The guy wants to make it handheld! Imagine the recoil on a 29Kj gun...
