  • Guests: 34
diode cleaning
teslacoolguy
Thu Dec 11 2008, 07:33PM Print
I went to the local metal recycleing place today and they had 3 DUAL Xray transformers. I was able to retreve 16 diode strings out of them but they are covered in oil residue. What would be the best way to clean them up?
aonomus
Thu Dec 11 2008, 08:17PM
Try a mild solvent like isopropyl alcohol, something really strong like acetone or even stronger could damage the plastics....
Thu Dec 11 2008, 08:44PM
Soap and water would probably be fine too, just make sure that with whatever you use you give it a good rise with DI water when you are done.
Thu Dec 11 2008, 10:05PM
I only use soap and water when cleaning up hydraulic oil. That and lot's of paper towel.
