  • Guests: 39
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Induction Motor Generator Questions...
Hon1nbo
Wed Dec 10 2008, 12:46AM Print
Ok, so I got this big, single phase [apparently induction] motor as a gift, but was told by my teacher that it cannot be used as a generator, but as I have found out: it can!
but there are some issues, mainly with magnetizing the "squirrel cage" before starting to generate and not letting that energy go away by using a cap, and in some cases applyin g power to use as a motor before removing power to have it generate...
after hooking it up to a multimeter and spinning it by hand, me and my friend got only around .0014V AC (expected to be low, since the thing is rated at around 1700 RPM). At home, I hooked it up to a drill and got around .117V AC, then I decided to try to magnetize the core by adding magnets, and after adding a couple to check for a difference (I was not going to leave them there for good) I noticed that there were brushings on the back of the armature, but no visible significant windings... after reading a little I found that it may be the "starter circuit" that gets the motor going in the desired direction by applying out-of-phase voltage.
Well, after looking that up, I set the drill at a higher speed, and got a reading of 0.85 VAC! (magnets attached)...
HOWEVER: I cannot get a Amperage reading on my meter, not even in the micro range...
so here is my question: could that starter circuit be shorting my output load capability? I do not know if I got it up to the rated speed (at which I was told by my teacher that the brushings would detach)... would the reason be something else?
I also tried adding the load after starting, which I read was preferable in the homemade induction motor generator pages online, but no effect was noticed.
Wed Dec 10 2008, 02:17AM
With an induction motor being used as a generator, you must have the right capacitance in parallel with the output. You need to run the motor a bit above its intended rpm. Do not put a load on it until it reached full speed, or it will not generate anything. Also, if you do all that and it does not start generating, try either running it at slightly higher rpm, and once it is going reduce rpm until needed voltage is obtained, or turn it all off and connect the power leads to a DC source for a few seconds. Do not use 120 volts, just something like 12 will do.
Hon1nbo
Wed Dec 10 2008, 02:49AM
I realized that info, but I want to know how I can get a voltage to my meter, but no amperage reading...
Wed Dec 10 2008, 10:42AM
A DMM on the voltage range has an input resistance of about 10 Meg ohms. How much current does it take to develop 0.85V across that? How does that compare to the lowest current your meter can measure in its AC voltage range?
And yes, the secret to making an induction motor generate is putting capacitors across it. Accidents have happened this way when people used PFC capacitors that compensated the motor to exactly 1.0 PF. If the motor and PFC caps somehow get disconnected from the line, it tries to generate infinite power and bad things happen. In bigger motors the resulting braking torque can bend or snap the shaft.
(A cookie to the first 4hv member who can harness this effect to make a compulsator)
GeordieBoy
Wed Dec 10 2008, 10:50AM
Yes, you always under-compensate induction motors with PFC capacitors. That puts the resonant frequency higher than the line frequency so that it does not get excited as the motor gradually spins down.
Improper over-compensation of a large induction motor results in an initially gentle drop in RPM when the power is removed followed by a sharp thud, fused components or bent metal when the RPM goes through the resonant frequency!
-Richie,
Hon1nbo
Wed Dec 10 2008, 01:29PM
Steve McConner wrote ...
barely within the DMM Amp range, but nonetheless within the supposed range (I plan to get a much nicer one anyways)
and on the caps I noticed that it could be bad, but I never knew it could be that bad! thanks for all of the info...
but my main question still hasn't been answered, as I used the methods that do not require the induction motor to have a cap connected, but still have exceedingly low power: could these brushings be affecting my output power? why are they there iof it an induction motor? are they there to get the motor started in the proper direction?
Wed Dec 10 2008, 02:11PM
As far as I know the slip rings are part of a centrifugal switch that opens the starting winding when it's up to speed, like your teacher said. The starting winding isn't continuous rated, and would burn out if it were left on all the time. (don't ask how I know this!)
To use an induction motor properly as a generator, you need a capacitive load, period. Sticking magnets to the rotor won't do much of anything, because the rotor needs a time-varying field induced in it. It's soft iron, too, so it doesn't hold magnetism. You can't flash it like a generator from an old Chevy or whatever.
Hon1nbo
Thu Dec 11 2008, 01:54AM
ok, i get that i need the caps to use it properly as a generator, but my question still is not being answered: for the voltage i am getting out, my current should be within the range of my meter, but it is not measuring any, though it is measuring voltage: is my DMM broken, or are these rings affecting it?
I am NOT trying to get usable power at the moment, I really need to know if my DMM is functioning right before I get into figuring out what cap to attach and a system to properly add the load...
rp181
Thu Dec 11 2008, 02:01AM
me like cookies... is there anywhere i can read some more on this effect?
