  • Guests: 53
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
testing the igbt shunt regulator
Mon Dec 08 2008, 02:12AM Print
I was testing the shunt regulator and it was doing well. The Rshunt is 8.3 ohms. I was increasing the voltage with a variac and did not exceed 100v. Where I have the IGBT on the schematic it is really 4 in parallel and can handle 600W.
Once I exceed about 60v the voltage would not increase as I increased the variac. I could see the ammeter needle oscillate around 7 or 8A. I turned the system off and tried it again. This time the CE path was completely open. I guess it is latched. I don't know if I fried the chips or if I have to do something to get it back to the normal state. Any help? What can I do to prevent this?
1228702332 190 FT0 Img 1082
Mon Dec 08 2008, 02:37AM
Why are you using an IGBT for a linear application? Although it will work, they are generally poorly suited for linear applications and better for switching applications.
I would use a MOSFET.
Mon Dec 08 2008, 02:50AM
I'm just experimenting right now. I have MOSFETs for the application, too.
That being said, is there any way to fix my problem with the IGBTs? How would I prevent this in the future?
