  • Guests: 39
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Electricity from tree
Johnp
Sat Dec 06 2008, 08:54PM Print
Johnp Registered Member #488 Joined: Tue Oct 24 2006, 02:19AM
Here is a video I just made, a half hour ago, while I was at home and bored - some of you may be interested.:
As my youtube comment says:
I'm tapping into a small flow of electrons from a Norway Maple. Giving
me about 0.634 volts to ground, in the microamp range. I can find
nothing on google as to how exactly it is working, so I have to form
my own hypotheses:
A) electric charge in
the air (especially now that it is winter) is being picked up from
every part of the tree. The electrons pass through the bark and into
the cambium layer, (zylom & phloem) tubes) as there will be lower
resistance for them to make their way down to the ground. There is
step potential between tree and ground (think of hanging onto an
electrical wire with one hand... you would be fine, but two hands and
you are in parallel with the line and some of the voltage will run
through you). In this case, my multimeter is in parallel with the
tree, and with that providing a path of lower resistance than is
provided by the water/sap down to the base of the tree.
B.) This may not be from collection of charged particles, rather,
active transport of electrons from the ground up through the xylom
tubes.
If anyone has a different hypothesis, let's here it!
I do videos like this, because it's fun and educationally rewarding,
of course, but I upload them, more importantly, with intent to inspire
those who watch. Maybe some of my videos will give you ambition to
start constructing projects that help you better understand the
universe. Question. Think critically. That's what we're all here to
do, all of us, students among a world of complexity. Hypothesis, test,
learn, apply. Then we reproduce to make more students. Now go
experiment! :D
Cheers to all and happy holidays!
John Paine
Second Year Engineering Physics
big5824
Sat Dec 06 2008, 09:03PM
im guessing friction between the air and the tree causes static to build up, which like you said can flow down the zylom and phloem tubes to earth
Johnp
Sat Dec 06 2008, 09:19PM
I know during the great depression that people would take thousands of feet of insulated cable, draping it back and forth over their house, connect one end to one leg of a high voltage capacitor, and the other leg of the cap to ground, allowing them to run a small neon tube, all night.
Now I'm thinking it might be off of the powerlines. I'll have to do it sometime out in the woods.
Sat Dec 06 2008, 09:47PM
John, you may find something to interest you in these two articles:
ULF Tree Potentials and Geomagnetic Pulsations (Nature 6 Feb 1978)
Trees as Antennas
Sat Dec 06 2008, 11:56PM
I suspect that using a copper rod and (galvanized) iron electrodes is the main source of potential difference.
To test, put the copper rod and one of the electrodes in water with any electrolyte (acid, alkali, salt etc.)
I guess you'll see about the same voltage.
ragnar
Thu Dec 11 2008, 05:53PM
There's an EngineeringTV video covering this too, you might find it interesting:
http://engineeringtv.com/.../tree-voltage-and-forest-fire-prevention.aspx
cduma
Fri Dec 19 2008, 07:50PM
I have done this before. I would like to see if anyone can power something with a tree
Chris Russell
Tue Dec 23 2008, 05:50AM
Chris Russell ... not Russel!
Sulaiman wrote ...
I have to agree, that's the most likely source of the small voltage present. Should be easy enough to test. Either drive a copper spike into the tree, or use a galvanized steel rod in the ground.
Some of the trees around here grow pretty close to power lines. I wonder if it might be possible to get enough energy to light an LED or something. Not free energy, but "free to me" energy.
