  • Guests: 40
Apparently around 20 microwave caps is enough to explode stuff?
1 2 3 4
Thu Dec 04 2008, 09:51PM Print
Well, i have some large GE caps(only one is any good), it was on a thread here before, and i decided to charge it up and see if it worked. Well, the capacitance is only 12.5uf and max voltage is i think 7650 volts, which would be 365 joules. I decided to charge it with a mot instead of my pig to be sure it worked. That is about 25 joules. I just grabbed a microwave transformer and hooked it pretty much straight up, with a diode and two current limiting resistors, which are each 16kohms, in series for 32kohms and about 24 watts. It charges in about 4 seconds, and after a few charges and discharges the resistors get hot enough to boil any water on your skin :P.
I did a few discharges, they were pretty loud, but not requiring any ear protection. I decided to get some very thin(~36 gauge) wire and see if it would just blow the end off. Well, to my amazement it blew the whole thing up! And this is only 25 joules.. So i cut a few pieces of aluminum foil, each about 1/4 inch thick and ~3 inches long and it blew up too! It was fairly loud, so i put ear protection on :P. Well, i decided that was still not fun enough, so i cut some thin slices of pickle. They where about 3/8th inch, and they got a hole blown in them.
This is roughly equal to 12-20 microwave caps. The problem with this cap is that is weighs about 30-50 pounds. But, it is made for i think it was 150kvar. But that doesn't matter really. The inductance is probably low though, so microwave caps may not do quite as good. You could even take it a step further and get 20 microwave caps and put 2 in series and 10 of those strings in parallel for faster discharge times. If you had all the caps the same and 1uf, that would be 10uf and 4kv, which is 80 joules, much more than my cap at 2kv! But at 4kv my cap is 100 joules.
By the way, i measured my cap to be 12.5uf, not just something i think.
Be careful though!
Mattski
Thu Dec 04 2008, 11:16PM
From what I've read, microwave caps will eventually fail when pulse-discharged and can explode. Here's an old forum post: Link2 so use them at your own peril and take precautions.
And their ESL and ESR is definitely going to be worse than a real pulse capacitor, but they might be good enough to blow some things up. And remember: 2 in series by 10 strings in parallel is just 5uF because you divide capacitance when you put them in series.
Thu Dec 04 2008, 11:39PM
Mattski wrote ...
Haha oops, i see what i did. I knew that there was 20 caps so i multiplied .5 by 20... Well, 40 joules then.... And yes, i know that microwave caps would explode. Just saying :P.
LithiumLord
Fri Dec 05 2008, 12:06AM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Well, MO caps will explode as an experiment I saw on YT proved. However you may get the current below the maximum pulse current for them by means of inductors. Bad that current is a mystery afaik :(
teslacoolguy
Fri Dec 05 2008, 03:23AM
According to Steve Ward here Link2 he was able to charge mo caps to 8kvdc each before they broke down and they took the breakdown very easily. I would go with a happy medium and charge them to max about 5-6kv depending on what they are rated. They are not the best solution for high power discharge but they will work to some point.
Fri Dec 05 2008, 11:42AM
A collegue from work tried with 18 MOCs and he would have to discharge them real fast in order to get some of the charge before it was burned by the internal resistors.
He charged the caps with around 4-5 kV and exploded more HV diodes than cans :) But he did get to crush some cans abit.
But its not worth the time getting them compared to finding some bigger lyttics or pulsecaps, atleast dont invest money in it.
Billybobjoe
Fri Dec 05 2008, 08:17PM
MadsKaizer wrote ...
I disagree with that statement. Have you checked the prices on pulse caps lately (even on eBay)? Electrolytics are cheaper but then you need a massive freewheeling diode and they're slow, even compared to MO caps. See Steve's page here (again): Link2 The ESL is pretty good considering the price.
Thanks to Steve Ward's idea I obtained 25 MO caps from a surplus site for $1 a piece. I'll get some pics of my setup later but it crushes cans and explodes wire like a champ. I've shot some 40 shots off with my bank (at between 6 and 7kv) and they are still holding strong.
Fri Dec 05 2008, 09:12PM
interesting. the problem would seem to be safety- all that energy being dumped into one cap would be a severe shrapnel hazard!
-A
Billybobjoe
Fri Dec 05 2008, 09:35PM
Conundrum wrote ...
-A
Definitely! I meant to cover that in my first post. Parallel capacitors are likely to destroy the one that fails . . . Mine are enclosed in a solid plywood box with a thick clear PETG top. Luckily, the internal resistance as MadsKaizer mentioned earlier happens to be a good safety feature. The caps tend to discharge very quickly without continuous charging - my charging circuit is designed (by the help of some forums members) to stay attached when the bank is fired. By themselves the caps will go from a full charge to empty quickly - maybe 10 seconds - and if you are doing that often be aware of power dissipation in the enclosed container. 25 capacitors in parallel seems to be the maximum for a 9/30 NST - any more and you'd need a current upgrade to reach 7 or 8 kv quickly (and when you're overrating the voltage like in this case you want to keep the time charged/charging down to a minimum).
EDIT - See here as well for some good information: Link2
aonomus
Fri Dec 05 2008, 09:44PM
Don't most modern microwave caps have built in bleeder resistors? Could the bleeder resistor heating via continuous charge contribute towards the heating and eventual explosion, or is it just dielectric breakdown?
