  • Guests: 60
voltage multiplier with DC voltage work or ????
Egyptian man
Tue Oct 05 2010, 07:51PM Print
Egyptian man Registered Member #3243 Joined: Sat Sept 25 2010, 11:44PM
hii
i wanna ask if voltage multiplier with my DC flyback is it work and if it work or not i want trusted design for voltage multiplier (( capc. voltage )) i think 3300 nf 4 kv is ok ???
i have my owm chuber transformer is it work on any diodes& capacitor
thnxxx
teravolt
Wed Oct 06 2010, 03:14AM
Check your flyback oscillator for output, is there a spark. Check your wiring against your circuit. Are your components tested good?
Egyptian man
Wed Oct 06 2010, 08:56AM
my flyback is working good .. just i wanna to plug a voltage multipkier is it work on DC voltage which come from flyback output???????????????????
Wed Oct 06 2010, 09:45AM
The only way of 'multiplying' a DC voltage that I can think of involves voltage summing.
For example, 10 identical capacitors are charged to a voltage E, and then connected in series, so that the total voltage across the capacitor string is 10E.
It is possible to do this mechanically: the capacitors are charged in parallel, and then connected in series by a mechanical switch to add all the voltages together.
It is more usual to use electronic switches. I will divide these switches into groups, and give examples of each:
Spark gap
Pseudospark gap
Trigatron
Krytron
Sprytron
Thyratron
BJT transistor
MOSFET
Thyristor
Solid dielectric gapped switches
Liquid dielectric gapped switches
All of these switching devices can be used as the switching elements in the voltage summing circuit called the Marx Generator, but only the first three types of switch - the different sorts of spark switch - will be suitable for use at the output voltage of your flyback.
You can also 'multiply' a high DC voltage with a device called a Vector Inversion Generator - VIG - where a pulse, and the reflection of a pulse returning down a transmission line, are added together to 'double' the voltage.
Antonio
Wed Oct 06 2010, 12:44PM
A mechanical switch can really be used, as in Planté's "rheostatic machine":
Lef595
Wed Oct 06 2010, 01:01PM
Antonio wrote ...
Lef595
How wonderful, Antonio! smile
I think there is still a good case for voltage addition using mechanical switching in some specialised one-shot devices.
Antonio
Wed Oct 06 2010, 02:56PM
A description of the "rheostatic machine" appears in this book:
