  • Guests: 38
charging capacitors with a flyback?
Solidacid
Thu Dec 04 2008, 12:53PM Print
Solidacid Registered Member #1430 Joined: Sun Apr 06 2008, 11:12AM
hey guys.
i was hoping you could tell me where on This (the usual single-transistor-driver) flyback driver i would connect a capacitor to charge it with the HV output.
tonight me and some of my friends are attempting to make a small flyback driven tesla-coil :D
thanks.
Solidacid
Thu Dec 04 2008, 06:12PM
Solidacid wrote ...
hey guys.
thanks.
Solidacid
Yes, you can but the sparks will be very small, and you will likely not get any streamers. The cap needs to be around 20-30kv i guess and a few 100 picofarads.
The flyback, however, has to be dc. You can actually get pretty good sparks with a bigger driver, like the ZVS or a halfbridge, and even the 555 driver will get you some ok sparks, but you may get more voltage from the flyback than the tesla coil depending on the power you run it at.
Thu Dec 04 2008, 10:53PM
I have made arcs of over 300mm/1ft using a 1.4 watt flyback powering a spark gap TC.
The thing is the repetition rate was very low (about 1 bang/second)
Very roughly, the length of a TC arc is propotional sqrt(energy)
so a low power flyback can slowly charge quite a large (e.g. 1 to 10 nF) primary capacitor
if you don't mind a very low repetition rate.
