  • Guests: 42
Powered armature in a coilgun
kromsson
Thu Dec 04 2008, 09:17AM Print
kromsson Registered Member #1444 Joined: Tue Apr 15 2008, 06:55AM
I have this setup in mind:
A LONG tube made of teflon (low friction), with two flat rails inside connected to the same source as the coil around the tube.
The armature is powered by contacting these rails, on its way out. It contains a small coil, aligned so that it is pushed away by the major coil of the barrel.
The armature is positioned inside the barrel, close to the middle. When powered both, the coil of the barrel and the coil of the armature, the armature will be accelerated towards the nearest end. The magnetic force will be applied on the armature even after it leaves the coil, degrading to zero soon after.
This way, there is no problem of timing correctly, as the force applied on the armature has the same direction always.
Thu Dec 04 2008, 02:53PM
Good idea. This is the linear equivalent of a rotary dc electric motor. Some components such as spring-loaded carbon brushes might be directly adaptable. The powered armature coil will greatly increase field strength that interacts with the stator.
The tricky part is the fabrication and machining tolerances. If you have some skills this would be a truly interesting project!
Why do they make cat food in those cute little shapes? Do cats really give a damn?
kromsson
Thu Dec 04 2008, 06:00PM
These might not be necessary, as the armatures will only be used once (what a loss!)
However, the rails inside the barrel should be lubricated with carbon dust.
CyrusTheGreat
Thu Dec 11 2008, 02:54PM
CyrusTheGreat Registered Member #537 Joined: Sun Feb 18 2007, 07:22PM
This has actually been done before (sort of). Look for what is known as a SPEAR coilgun. A coil of wire is pulsed to build a magnetic field, then disconnected from the electrical source. Before the magnetic field dissipates it is accelerated down a tube with external coils. The efficiency of the design that I saw was rather high something like 20% (I don't have my IEEE login right now so...).
kromsson
Fri Dec 26 2008, 10:29AM
I saw the SPEAR coilgun. However, besides the powered armatur, I suggest another concept:
Instead of attracting the armature, the external coil will REPEL the armature.
The armature will be placed in the middle of the external coil (and a little to the exit) and the magnetic fields will be thus aligned so as it will be pushed out. This way there is no suckback, and the armature is pushed away even AFTER it leaves the coil.
The maximum force is applied at the end of the coil, and all you have to do is to adjust the length of the coil and the timing of the LC circuit.
