  • Guests: 92
Arjan EMM (52)
01/01 Bosko (56)
01/01 hen918 (30)
01/01 Yuri_Ivanov (35)
Best method for a multistage?
El_Roberto
Fri Dec 05 2008, 05:07AM
El_Roberto Registered Member #1774 Joined: Wed Oct 22 2008, 02:51AM
I think it might be easier to use a microchip (assuming you know enough about programming). You can get ones up to about 50mhz so that operates in nano seconds (I think).
rp181
Fri Dec 05 2008, 01:05PM
I can program (java) but ive never used a microchip.
Its not that complicated, instead of 6 555's, you can use 3 556's and 1 lm339.
Killa-X
Sat Dec 06 2008, 03:37AM
Hahahahaha I've programed ATTINY2313 and ATMEGA644 (64kb space) The most I made so far was a home made yahtzee game on a 20X4 character LCD. No sound yet. Luckily it supported 7 custom characters for the LCD. I've done multiple tests with bascom to simulate the LCD...
Its been months since I've monkey with my USB programmer.. I've been too much around Coilguns, Green lasers, and so on. I should get back to my chips :( I was thinking if i got a coilgun to work very good, I'll use my ATTINY2313 to drive parts of it, such as an automatic fire at X volts.. Yet.. with that LM311 from uzzors circuit, I could have it indicate 400V and trigger the SCR...... hmm :P
Also, heres a rough photoshop of my coilgun circuit.. very simple xD
Camel
Sat Dec 06 2008, 07:17AM
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
^^ I don't understand . . . your SCR has 4 connections.
rp181
Sat Dec 06 2008, 02:25PM
Capacitor bank anode,cathode, and gate anode and cathode. SCR's usually have 2 wires coming out of the "bank" cathode, because the gate cathode is the same.
Killa-X
Sun Dec 07 2008, 01:32AM
Ya, thats why they are both blue. I put it the 2nd blue on because the back is the same and I was too lazy to go around to the blue on the other side. It's 3 pin, trust me.
