  • Guests: 35
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Switched power supplies
Tue Nov 25 2008, 02:21PM Print
Based on a comment from a previous thread, I have been reading about switched power supplies. I build a simple power supply years ago using a step-down transformer, rectifiers and capacitors, and for my purposes it functions well enough. If I understand correctly, a switched power supply stores energy in an inducutor by turning a fet or transistor on/off. What advantage does this offer over the way I did it?
Tue Nov 25 2008, 02:44PM
A switching power supply uses ferrite magnetic components (chokes/transformers) which operate at a high frequency (tens to hundreds of kHz). This allows for considerable weigth reduction of the supply. It also offers better regulation of the output voltage without dissipating extra power in a linear regulator.
GeordieBoy
Tue Nov 25 2008, 04:26PM
In production volumes the advantages of Switched Mode Power Supplies are:
Reduced size
Reduced cost
Reduced weight
Improved performance
The improved performance can mean better efficiency, better line & load regulation, 120/240V supply acceptance etc.
The downsides of a switched mode design are usually higher line and load side noise, complex design and more complicated to test properly, longer design leadtime, and a much greater risk of getting something wrong!
Switched Mode Power Supply design IS a specialist field, which requires knowledge of power electronics design, magnetics design, thermal management, PCB layout, control theory and EMI management / RF design. Even the professionals frequently overlook something and SMPSUs go to market with little design flaws.
For the reasons stated above, I would always recommend a linear power supply for hobby projects unless it is going to go into high-volume production where the reduced cost/size/shipping weight become important. OR unless the high efficiency of a well-designed SMPS is the only viable way of meeting the design spec.
Wikipedia gives this explanation:
-Richie,
Tue Nov 25 2008, 05:43PM
Thanks for the answers. This certainly clears things up. I was able to put together my supply in few hours and it works well. I can put out over 10A, but I rarely need more than a couple so my voltage regulation is fine for my needs. The switched design is interesting, but nothing that I need at this time.
