  • Guests: 64
01/13 si2030 (62)
Diode Split transformer - reverse voltage
baleworker
Sat Nov 22 2008, 10:07PM Print
baleworker Registered Member #1596 Joined: Fri Jul 18 2008, 08:43PM
I am trying to make a diode split secondary, and wondering what reverse voltage diodes will experience?
From my calcualtions, it turns out to be that each of them will get Vsecondary/Nsections. However after trying to run a simulation, I am getting weird values: for 6.45kV, 4 sections secondary the distribution looks like : 400-2410-810-2830
Am I missing soemthing?
Please help!!!
Sat Nov 22 2008, 10:19PM
They should all see the same voltage, that's if all of your sections are the same (all wound "down-up" from the core, hope you know what I mean).
Maybe you have the sections wound alternatively (one wound "down-up", second "up-down" etc.), in this case the winding-to-core capacitance will play some role in unevenly distributing the voltages, but I believe this winding scheme is never used...
baleworker
Sun Nov 23 2008, 02:13AM
I finally found a schematics of full wave diode split rectifier. And simualtion runs great now! Each diode gets what theory predicts.
Before I was trying to use a center tap design to get a full wave rectification with segmented secondary.
Wow... I just figured out how to cut a number of turns in half!!! :) :) :)
