  • Guests: 34
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
looking for quicker charge times with disposable camera circuit- 400v & 3760uF caps
casey
Fri Nov 21 2008, 02:27PM Print
casey Registered Member #1787 Joined: Thu Oct 30 2008, 12:33AM
my teacher is requireing us to use a single 9v batter to charge our coilgun. Is there anything i can do to speed up the charge times. Can i use like a car batter, just during testing, and will it bee quicker, or will it fry the disposable camera transformer?
Zenador
Fri Nov 21 2008, 03:34PM
Zenador Registered Member #1733 Joined: Thu Oct 02 2008, 03:17PM
The 12V car battery may not fry the transformer, but it will fry the transistor. I connected a 12V 1500mA wall-wart to one and I got a pretty flame from the board... I've driven the board to 8V (9.5VA) without blowing anything, but things do get warm.
Build a small CW Multiplier for the HV output from the board. In the projects forum, there is a thread on the camera-flash board tesla coil. That circuit will charge a small cap bank. How big is the cap-bank?
Z
Fri Nov 21 2008, 05:17PM
Make a boost converter. They will boost 12 volts up to 600 volts, so a 9 volt battery could do 400 volts.
Uzzors' is my favorite, because it is easy to understand and he gave a good explanation.
KLH
Fri Nov 21 2008, 08:22PM
I agree with Arcstarter's suggestion of building a boost converter, as even the most basic design will usually be able charge a capacitor bank faster than a disposable camera flash circuit.
However...
Arcstarter wrote ...
The theoretical output voltage of a boost converter is infinity, it just depends on how long you let the converter run.
So a comparator is required to keep the converter from overcharging the caps.
