  • Guests: 35
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
MC1377/TEA2000 + TV glasses 3-D mod
Tue Nov 18 2008, 01:31PM Print
Hi all.
Seems that there may be another trick I can do to enable 3-D on those glasses.
I obtained a surplus TEA2000, and after winding the 2000+ turn luminance delay (ugh) and soldering it dead-bug style onto a solid ground plane it works fairly well.
Also did some transmission tests with the R/G/B LED's I purchased on Ebay to ensure that the green only passed green etc.
The plan is to replace the white backlight on the glasses with the LED's having modified them into a thin block format (to reduce distortions) and drive them in pairs so that they can be switched on in the order G (left) RB (right) or RB (left) to green (right) to enable the 3-D effect.
This has the advantage that it elliminates flicker and reduces crosstalk between the displays to near zero.
I have also determined that using the odd/even frame output from the LM1881 will allow me to get 6 levels of colour instead of 3, as the brain will "fill in the gaps" so to speak.
As for A-D, this does make things a little more complicated. I will need to have three independent sets of comparators (i.e. four chips) with each set up to increase the threshold level on receipt of an even frame input.
I may also be able to generate colour pictures using a PIC 12F675 triplet set up with common 27MHz clock so that you can overlay a number of input signals in different colours.
Pics soon smile
-A
"Bother" said Pooh, as he ran out of wire mid-secondary...
Backyard Skunkworks
Tue Nov 18 2008, 07:23PM
Hehe sweet! shades
Wed Nov 19 2008, 06:13PM
Ran into a problem- due to an apparent wiring fault or earlier overvoltage the TEA2000 has stopped generating video. I fixed it with 1K resistor between vout and +V as it appears the internal video buffer has become damaged.
I also determined that the TTL inputs need a 1.5K resistor between them and ground to get meaningful video- hooked up simple resistive divider to get a "false colour" image.
Adding video buffer or other A-D (guess what, resistors don't have a bandwidth!) should be enough for what I need :)
Next idea is to generate the colour burst (10 cycles of 4.43MHz) and colour subcarriers using a PIC 12F675 running at 17.734451 MHz which would enable me to experiment further. (or just cheat and use a MC1377 which turned up today)
Sat Nov 29 2008, 09:34AM
As promised, here are some pics of the myvu's guts.
Looks like the backlights are driven in series from a +7-8V supply (2*3.9V) so i can probably mount a PIC in place of one of the LED's and use the existing wiring to get the phase switching.
I did read somewhere that PIC micros can have the outputs connected together through resistors to get higher drive current...
I have two headphone leads to work with, so superimposing a >15 KHz signal onto the right hand one nearest the micro by adding a series capacitor should be enough to control the backlights. Also there will be no brightness control unless I can switch the LED's somehow (possibly with a resistor to drop them below 2V)
Might not even need that, just a simple initialisation pulse on the headphone line and accurate timing on the PIC could work.
EDIT:- you need to use SiC based LED's not InGaN or GaN or the colours will bleed through and cause blurring.
1227951396 96 FT1630 Guts
1227951396 96 FT1630 Guts1
1227951396 96 FT1630 Guts2
1227951396 96 FT1630 Guts3
1227951396 96 FT1630 Pcb
regards, -A
