  • Guests: 45
Uzzors boost converter
Camel
Sat Nov 15 2008, 11:51AM Print
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
Hi,
Shouldn't the + and - pins of the LM311 be the other way around?
If + is greater than - than the output will be high. High output will turn on that LED and reset the 555. When you first turn that circuit on, the voltage at the + pin will be 6V and voltage at - pin will be 0V, so the output will be high. High output when the circuit turns on? Doesn't sound right to me.
Is there something wrong with my logic? or should the + and - be the other way around.
big5824
Sat Nov 15 2008, 03:03PM
pin 4 on the 555 isnt reset, it has to be high for the 555 to be active. So when the output is high, the astable is running, and when its low the astable stops
Camel
Sat Nov 15 2008, 03:20PM
Oooh, ok thanks.
