  • Guests: 32
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Temp resistent glue and other question
Wed Nov 12 2008, 07:46PM Print
I need a glue which is good up to 150°C. Do you think superglue is good? Or would you recommend something else?
Because I dont feel like starting 2 threads, here is another question, I have a "hardpaper" transformer bobbin, what should I paint/impregnate it with to make it resistant to moisture?
Marko
Wed Nov 12 2008, 07:59PM
Hi,
If you need quick and reliable setting, check for epoxy glue. I think most of them should stand 150C today.
I wouldn't use superglue for that kind of temperature.
If you need large amounts at affordable cost, check for polyester boat resin. It requires much more time to set, produces a lot of heat if setting fast any may be troublesome... but here it is like 10 times cheaper than epoxy. By requirement, it can be thinned with styrene.
I use the same stuff to impregnate cardboard as well. I think it's better than the industrial transformer varnish, which is solvent based any may not dry well in deep gaps.
Marko
Camel
Thu Nov 13 2008, 08:01AM
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
Super glue shouldn't be used above 120C. Araldite/epoxy glue also weakens when it gets hot, but its gotta be better than super glue.
rp181
Thu Nov 13 2008, 01:22PM
Enamel might be good, or even just some electrical tape.
What is the glue used for? Whats the material?
Thu Nov 13 2008, 02:53PM
I found a 1kg box of the boat epoxy in the shed so I tried it... it cures in 24 hours so I'll see tongue
Electrical tape?? I'm pretty sure the tape itself melts at lower temperatures... It is for gluing some plastic insulating sheet (dunno the material but it was used as a heat transfer medium for FETs) to a mot.
Thu Nov 13 2008, 04:02PM
RTV Silicone is normally good up to 260 deg. C
Cheers, Finn Hammer
ConKbot of Doom
Sat Nov 15 2008, 08:10PM
JB weld is good for a decently high temperature, (I wanna say 600F, but not sure) and you can thin it with acetone. Not how sure how much you can thin it however.
Sat Nov 15 2008, 09:18PM
I also heard that JB weld is good. I heard of a guy that apparently glued up an engines crankcase with it, but i am not sure how much i believe that. Also, i know that people have used it to glue pvc pipes on engines for use as a ghetto muffler.
Permatex® - Black Silicone Adhesive Sealant
General purpose, black RTV indoor/outdoor sealant. Seals, bonds, repairs, mends and secures glass, metal, plastics, fabric, vinyl, weather stripping and vinyl tops. Maybe applied to horizontal or vertical surfaces. Waterproof and flexible. Temperature range: -80°F to 450°F (-62°C to 232°C); resists oil, water, weather, vibration, grease. Non-paintable. Suggested applications: Use where resistance to extreme thermal cycling, ozone and UV light is required.
I also found this data on Bostik's 9732 RTV silicone sealant, which may be of interest to you:
Volume Resistivity: ohm-cm 1.5X1015
Dielectric Strength: volts/mil 550*
Dielectric Constant: @ 100 Hz 2.8 @ 100 kHz 2.8
Dissipation Factor: @ 100 Hz 0.0015 @ 100 kHz 0.0015
*This American notation works out at 21.7kV/mm
Doubl3 Helix
Sat Nov 15 2008, 10:02PM
Doubl3 Helix Registered Member #1548 Joined: Mon Jun 16 2008, 09:22PM
I know a guy that had a hole in the crank case of his Quadracer 250 from when the chain broke off. He sealed the hole with a little JB Weld, and it's still perfectly fine...
