  • Guests: 43
01/13 si2030 (62)
Thyrister bank good enough?
Backyard Skunkworks
Mon Nov 10 2008, 03:44AM
Hate to disagree with rp181, but this will not end well. Your dealing with 475J at 450V.
Everything is going to go boom within a couple shots, this is pointless.
Either switch it mechanically or get some SCRs designed for this.
guitardude012
Mon Nov 10 2008, 09:18PM
guitardude012 Registered Member #968 Joined: Fri Aug 24 2007, 04:54PM
edit: I had some comments here about what you could try, but then checked some equations and these will absolutely fail.
I have had success putting SCRs in parallel. I choose the littlefuse TVR SCRs for their fast turnoff time(S6055R). Four of them in parallel haven't failed switching a 400v 7800uF cap bank fired at 340v+ over 200 times. S8055R would be a better choice for 450V.
Joule switching potential is a better measure way to rate SCRs but these numbers are hard to find and coil parameters(inductance, resistance) will make a difference.
edit: I agree with Electroholic's recommendation as long as you aren't planning to v-switch
Solidacid
Tue Nov 11 2008, 09:39PM
Solidacid Registered Member #1430 Joined: Sun Apr 06 2008, 11:12AM
hmm.. seems like i will have to go with a mechanical switch then(the few SCRs i found in denmark cost about about 3-4000Dkk(514-686$))
