  • Guests: 37
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Rattling capacitors!!!
El_Roberto
Fri Nov 07 2008, 05:05AM Print
El_Roberto Registered Member #1774 Joined: Wed Oct 22 2008, 02:51AM
As the title says I have some second-hand electrolytic capacitors that rattle! I have 20 of them for my 20 stage coilgun project and about 7 or so rattle when shaken lightly. All show above rated capacitance using a capacatance meter, but i havnt tried to use them to fire anthing yet. Any idea's why?
Fri Nov 07 2008, 09:00AM
They could be fakes, or maybe the electrolyte has dried out.
Chinacapacitorek1
El_Roberto
Fri Nov 07 2008, 09:25AM
Lol not fakes, I used one in my coilgun and it worked fine. Is there a way to fix the electrolyte or are they screwed?
Fri Nov 07 2008, 11:16AM
I had some big electrolytics that rattled, and while they seemed to work fine, and held a charge at their 450V rating, I ended up throwing them away. I was worried that they were dried out and might overheat and blow up under high ripple current.
Bjørn
Fri Nov 07 2008, 12:20PM
I had some in an amplifier and they seemd to work fine until suddenly they lost all capacitance and my amplifier turned into a 50 Hz generator.
El_Roberto
Fri Nov 07 2008, 08:53PM
Well that sucks, im going to see if I can get a refund. Guess that puts an end to my project, I cant find any other capacitors close to this size for any less than $50 each.
Fri Nov 07 2008, 10:04PM
What size do you want each capacitor to be? Alltronics has some nice computer grade caps for really cheap. They are 3900uf and 400 volts each and for 4 of those capacitors it is only ~25 bucks! That amounts to 312 joules each!
Top link is for 4 of them and the bottom link is for one.
They may not be made for pulse discharge but they sure as hell do hold quite alot! I bought two of them and i say they are quite good! I discharged them into a dead short at full voltage a few times and they didn't die. I also exploded some wire with them. And all of that was without a protection diode! I thought one died at one point because it would charge to like 12 volts and stay there, but it turns out the diode i used to rectify the charger died, and the capacitor still works to this day.
El_Roberto
Fri Nov 07 2008, 10:44PM
Wow thanks, thats insanely cheap, the caps I was going to use were only 50joules each and cost only $10 less for 4. Im going to try and order 4 now! You may have just saved my project.
Edit: well ill have to think about it, shipping is rediculous. For 20 shipping is $240 for only 1 its $40!!!! Thats almost 6 times the cost of the capacitor.
Fri Nov 07 2008, 11:06PM
El_Roberto wrote ...
Wow, i am sorry to hear that, that really bugs me that it costs SOOOOO MUCH. it only costed me like maybe 10 bucks for a 5 pound bag of capacitors and 2 of those capacitors from that place...
Keep a look on ebay, they sometimes have similar caps and you may get away with cheap shipping.
Update: Link2
Those are the same ratings, but have some aesthetic damage. It may also be high shipping and they may not even ship to you.
I will keep looking.
edit. And one more thing, thank you teslacoolguy for the link to alltronics, he is the one that gave me the link when i wanted to make a coilgun.
