  • Guests: 50
Cprossu (40)
Kokamo (46)
GalliumMan (60)
12/30 Alex_FX (45)
12/30 Pieznice29 (31)
12/31 Arjan EMM (52)
Help needed with first coilgun and little knowledge
Prodks
Thu Nov 06 2008, 11:29PM Print
Prodks Registered Member #1800 Joined: Thu Nov 06 2008, 11:23PM
Hi all, i need to do this for a school project and think this is the place where I can find some help, so here it goes. Look at the attached file, thats how my project is today, I`m pretty sure I have to attache a diode or something somewhere in the way to the coil, but i dont know where. I couldnt find this anywhere, so could you please help me? All the sugestions will be great to have. Thank you
1226014160 1800 FT0 Coilgun
Thats a light bulb right below the power source
[Edit: double post]
Bjørn
Fri Nov 07 2008, 12:46AM
You need to read this: Link2 and this: Link2
Everything you will ever need to know about coil guns is on the forum, in the archives or in the wiki. We don't answer these basic questions anymore because they have already been answered many times. To make sure you don't kill yourself or start a fire I have fixed your diagram. You should also have a safety resistor to slowly discharge the capacitor because it is dangerous if someone touches it while charged or partly charged.
1226018765 27 FT56928 Cgfix
Prodks
Fri Nov 07 2008, 03:09PM
thanks a lot
Andyman
Fri Nov 07 2008, 04:29PM
You also need to be absolutely sure the mains is disconnected before you fire it.
And to protect your capacitors, I added another diode across the coil:
1226075374 1083 FT56928 1226018765 27 Ft56928 Cgfix
It needs to be a relatively beefy diode.
Prodks
Mon Nov 10 2008, 09:15PM
i have some diodes from a pc power supply that have CT µA05 written on them, will those work?
Saz43
Wed Nov 12 2008, 07:58AM
Saz43 Registered Member #1525 Joined: Mon Jun 09 2008, 12:16AM
Not likely. You are going to want a fairly large diode since you are likely to have a good amount of current running through it. Try a rectifier diode (google it) which is designed large currents at high voltage.
Prodks
Wed Nov 12 2008, 11:11PM
could you give me a number or something that i could look for in a store, cause i have to deliver this next week
, so internet is not an alternative, cause i need to get it in no time
Prodks
Wed Nov 12 2008, 11:12PM
i mean diode specs, like amperage voltage and such
Prodks
Mon Nov 17 2008, 12:15AM
i got two 6A 600V and two 6A 1000V, hope thats enought, cause i`ve to deliver this tuesday
Backyard Skunkworks
Mon Nov 17 2008, 02:10AM
Putting all four diodes should work, with a bit of a safety margin.
You might want to invest in a 5-10 ohm resistor to put in series with those diodes just to be safe...
