  • Guests: 97
kywalda (63)
12/19 kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
Stupid Question
Saz43
Mon Nov 03 2008, 01:09AM Print
I am trying to use an SCR to trigger my coilgun. However, my SCR has two little wires coming out of it (one red and one white), instead of just one like in all of the diagrams and pictures. I guess what I am asking is what do I do with the extra wire??
Thanks,
Sazmeister
rp181
Mon Nov 03 2008, 01:23AM
white =gate
red = cathode. Its just a auxirally wire to trigger it, its the same thing as the big red wire.
Is it a stud?
Saz43
Mon Nov 03 2008, 02:23AM
Yes sir, like me, it's a stud.
Thank you very much. It should work now. Now just pray that something doesn't explode when the current come's a'rushin' through.
KLH
Thu Nov 20 2008, 07:19PM
A lot of SCRs have this extra wire / terminal, like the INT-A-PAK SCRs I'm using. This little wire, in addition to triggering, can be used for current sensing in a test setup with a current sensing resistor (0.001 ohm recommended) by reading the voltage from it.
