  • Guests: 32
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Crest Voltage
Thomas F
Mon Nov 03 2008, 06:52AM Print
Thomas F Registered Member #503 Joined: Sun Nov 19 2006, 06:37PM
Some jargon clarification :
Does crest voltage mean peak voltage ? Would this be the same as peak to peak voltage in case the voltage never goes negative ?
Mon Nov 03 2008, 09:10PM
First time I hear about it, and this is what wikipedia have to say
Thomas F
Wed Nov 05 2008, 06:43AM
Hi MadsKaizer,
Thanks for replying.
I saw the definition of crest factor, was not too sure about the crest voltage ( peak voltage ) part. I think I would have to assume that its the peak voltage on one side of 0.
Thomas
Wed Nov 05 2008, 11:04AM
As far as I'm aware, crest voltage means the same as peak voltage. It's very rarely used, most people just say peak voltage.
As for the peak-to-peak thing, peak voltage is defined starting from 0. That means that a waveform could have different peak voltages (and hence different crest factors) on its positive and negative sides. Usually you quote the larger of the two values.
Peak-to-peak isn't really meaningful, and I prefer to avoid it altogether.
Dr. Slack
Wed Nov 05 2008, 07:36PM
Peak or peak to peak are useful in different contexts. It's easiest to measure the amplitude of a waveform on a scope if you line up the bottom peak with a graticule line and read off where the top peak comes, less error than estimating the two peaks seperately and adding or averaging. The extreme of +ve and -ve peaks being different is the waveform from a flyback.
Thomas F
Fri Nov 07 2008, 05:27AM
Thanks Steve M and Dr.Slack.
