  • Guests: 44
Michael Witt (36)
AleSeg (15)
09/17 Jyardana (41)
09/17 Gunboat (72)
09/19 raff (48)
ETG - why so bad?
rp181
Sat Nov 01 2008, 12:46AM Print
I recently started expirimenting with ETG's. My first one was a plastic tube, a little less than 1/2". This worked great, and made a nice loud bang and a 2 foot long "flame". I got tired of the crappy construction, and made a new one out of 3/4" PVC (sch40). For some reason this seem ALOT weaker, and can hardly push the Al foil ball out of the <1ft barrel. Why is this?.
Im using a capacitor bank charged to 330v, 4 3900uf 400v caps in parrellel, and a voltage doubler with the same cap (acts as a charger and a 800v, 1450ug capacitor). After firing, there is still about 60v charge.
Firnagzen
Sat Nov 01 2008, 01:05AM
Firnagzen Registered Member #567 Joined: Tue Mar 06 2007, 10:55AM
You mean electrothermal gun, right?
I would hazard a guess that you're using more water in your bigger ETG. More water= more energy required to vaporize all of it, but you're using the same cap bank, so maybe that's the problem?
Also, perhaps it's leaking somewhere?
rp181
Sat Nov 01 2008, 03:40AM
Water? i am not using water, just some aluminum foil hard shorting the capacitor bank. Here are some still frames of the vid i took. The first one is with a "plug" on 1 end, and the other 2 are with both ends open.
ThThpix
ThThpix
ThThpix
Firnagzen
Sun Nov 02 2008, 12:48AM
Perhaps I've misunderstood? When you said ETG, I thought of an electrothermal gun- A cap bank is applied to a small amount of water, which is vaporized into steam to drive the load.
Or are you actually exploding the foil itself to drive the load?
Pretty pictures, by the way, if a bit blurry. But nice sparks.
But either way, my point still stands, with a bigger diameter, there's more stuff to vaporize, making it harder. Try using something like a ping-pong ball wrapped with foil? Though I'm afraid the ball may melt.
Backyard Skunkworks
Sun Nov 02 2008, 12:58AM
Looks like he's actually exploding the foil...
Is it even "healthy" to dump the bank (of lytics) over a flat short like that? How much would that affect the lifespan of the caps?
rp181
Sun Nov 02 2008, 05:07AM
its not even a flat short, when its finished, half the charge remains, and ive had thicker wires explode than this one. I think its fine to short lytics if its not high cycling rates, any input on this?
ETG can be water, but metal dust is used too (thats what larda did) I just dont have metal dust on me. There are two versions: plasma and vaporazation.
I have tried it with water, but its too powerfull until i make a proper setup.
The pics are blurry because its a frame from a video, 30fps =/
