  • Guests: 33
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
how many charges can i get with disposable camera circuit with a 2000uf cap?
casey
Thu Oct 30 2008, 11:52PM Print
casey Registered Member #1787 Joined: Thu Oct 30 2008, 12:33AM
i'm building a coilgun for school that must run off a 9v battery. will that battery even be able to fully charge the 2000uf cap? i'm using the standard disposable camera circuit at 300 and some odd volts.
Fraggle
Fri Oct 31 2008, 01:24AM
Fraggle Registered Member #1526 Joined: Mon Jun 09 2008, 12:56AM
Yeah easy, batteries hold loads of energy compared to capacitors.
Backyard Skunkworks
Fri Oct 31 2008, 01:43AM
Roughly 60 charge cycles assuming no inverter losses.
In reality you might get around 30-40.
Your cap is 108J, and a 9V battery holds roughly 6kJ.
