  • Guests: 29
01/13 si2030 (62)
[moved] does any one know how much voltage i will get using a mot back wards
Chris Cristini
Thu Oct 30 2008, 06:42PM Print
I am hoping to get 12 volts so i can get better results with my fly back driver. shades
Thu Oct 30 2008, 06:49PM
Lets say we got a MOT rated at 230V/2300V, turning it around would give us 230V/23V.
But you still have to consider its current abilities etc, and im not even sure the secondary is usable as primary for 230v, so somebody correct me please.
Alternative solution:
Cut out the secondary coil and wind a new one from some AWG16 isolated wire, I think I used around 30-40 turns and got up to 20Vac, with a variac you can can control your voltage, keep the mot from saturating and it wont overheat so fast.
Thu Oct 30 2008, 07:56PM
your living in a 120V land right? Then your transformer has approx. 1:18 ratio.
Running backwards: V=120/18=~7V AC.
The current available will also be pretty funny, roughly 1.4A into a direct short cheesey
Better remove the HV secondary and wind your own low voltage secondary on its place.
MRacerxdl
Fri Oct 31 2008, 12:45AM
Here I have winded more 6 turns for the primary and winded 20 turns for a new secondary, I get 18VAC and after retifed and filtred I get exact 24VDC, the short current is 100A (measured) but the wire only handle 45A (50A for the diode bridge)
Chris Cristini
Fri Oct 31 2008, 03:26AM
yes i do live 120 land i tried a rectifier and a 10.000uf capacitor and got 15vdc i am not sure how much current i get but its all good.
Myke
Fri Oct 31 2008, 04:42AM
Did you disconnected the wire from the core so that if you accidentally touch the core, you don't get shocked?
Chris Cristini
Fri Oct 31 2008, 11:56PM
Yes i did i thout about that don't like getting zapped.
Sat Nov 01 2008, 08:26AM
crazy4 wrote ...
Well the primary is not connected to core so even if you leave it in place you're isolated from mains.
Myke
Sat Nov 01 2008, 08:50AM
Dr. Kilovolt wrote ...
crazy4 wrote ...
From what I understand, he is using the HV sec as a primary to get a low voltage output. There is one wire connected to the core and that would go to mains.
