  • Guests: 63
01/13 si2030 (62)
SLR tested! Works! Wave Forms, need help!!!
baleworker
Mon Aug 18 2008, 02:44AM Print
baleworker Registered Member #1596 Joined: Fri Jul 18 2008, 08:43PM
So I switched to GDTs and finally got my drive doing something. Major problem I am having, rectifying HV diode heats up very fast and after it heats up, the secondary current drops significantly. It’s a cheap 0.5A 15kv diode off ebay. Ammeter starts at 80ma and goes down to 30 in a few seconds.
Voltages have not been measured yet, but it looks like around 10kV idle (sparks over 1 cm distance).
What could be a reason for it? I hope its not a diode working as a ballast resistor when voltage across the arc drops to 2kV and other 8kV need to go somewhere.
I also blew up the bridge once again. If you look at gate voltage waveforms, you can notice spikes which can lead to IGBTS being opened at the same time. Is any snubber or filter circuits I should use between GDT and IGBT?
Forgive me my stupid questions, but this is the first time I am doing power electronics… Any input is highly appreciated!!!
1219027322 1596 FT0 Gdt Gate Voltage Gate voltages
1219027322 1596 FT0 Gdt Primary Arc Primary current
1219027322 1596 FT0 Gdt Primary Half Power Arc Primary Current at half power
Mon Aug 18 2008, 03:12AM
Waveforms look pretty good. Ive fixed the gate drive overshoot issue with something like 10 ohms in series with the GDT primary.
If your diode is not rated for ultra-fast recovery times, then it will never work well for this circuit, and will always overheat from reverse recovery loss. Since you said it was "cheap" im guessing that its not a suitable diode.
Mon Aug 18 2008, 07:59AM
baleworker wrote ...
Why everyone gets these asymmetrical current waveforms? I have NEVER been able to produce symmetric waveform, even though my driver IC was a SMPS controller w/flip flop in it (meaning the outputs have exact pulse lengths and dead times)
Mon Aug 18 2008, 08:52AM
Hint: They look pretty symmetrical at half power. Maybe the asymmetry only happens after the "butt cheeks" have touched, and the cure is to never allow them to touch.
BTW, I hope we aren't helping baleworker out in his day job. He looks remarkably well funded with machine tools and digital scopes, and he never mentioned what the power supply was for.
baleworker
Mon Aug 18 2008, 12:39PM
Dr. Quit The Dr. Thing! wrote ...
Haha... my day job is computer programming, but I am a freak and spending a lot on tools and equipment for many of my hobbies. I built my shop over a few years, getting most of the stuff cheap, off ebay etc.
Waveforms do look symmetrical, though you can see the current always swings in positive direction a little bit less than in negative.
Steve, what recovery recovery time would you recommend for operation up to 200kHz?
Thanks a lot!
Mon Aug 18 2008, 07:53PM
I used diodes that are rated in the low 10's of nS recovery time, 50nS would be great. You could probably stand a little more, but really it will make it less efficient.
Most HV diodes are "standard" recovery, meaning they often take many uS to recover, this will eat up most of your power at 200khz. If you are using a microwave oven diode, then thats absolutely the worst thing ever, unless of course it came out of the newer switch mode microwave power supplies.
Id suggest getting a bunch of UF4007's or there are also some other types, i used to get the SF1600 from newark, there may be some BYV types too. It should be relatively easy to find 1kV 1A ultrafast recovery diodes on the cheap. They should mention avalanche ratings, which is helpful to string them up because you dont have to worry so much about balancing issues. The diode with the least junction C will take the most reverse voltage, so it will just begin to avalanche a bit to self balance. Still, i usually go 50% extra voltage rating on my HV diode strings.
baleworker
Thu Aug 21 2008, 01:50AM
Replacing diodes did help with their overheating, but they were not the reason for the current drop. It's a capacitor in series with primary. It overheats and cause primary current to drop!!!
How to solve this? What caps should I use?
I tried putting 10 smaller caps in parallel and it did not help at all, all 10 overheat like crazy!!!
Are there are any special caps for high current applications?
Please help!
Thu Aug 21 2008, 07:27AM
What is your power level? I never had any film or foil cap get warm in SLR, but these were low powers (~300W)
baleworker
Thu Aug 21 2008, 12:47PM
Dr. Kilovolt wrote ...
I am runing it at 200-400W continues at the output. Input current 5-6A RMS, half bridge off the mains.
Thu Aug 21 2008, 06:17PM
You have some junky caps then!
I use a CDE 942C20P15K i think, its their 2kVDC 150nF metal foil and film cap. Its rated like 13A RMS, i pushed it to twice that for awhile without it asploding :P. You need a pretty serious cap for this converter, not any polyester junk. It also has to have a pretty good VAC rating, preferably 600V or so! I guess this seems like no big deal to me because ive got boxes of high quality PP caps just laying around here :P. So go spend 5 bucks and get a decent part.
