  • Guests: 26
01/13 si2030 (62)
rectifying a square wave
Madgyver
Sun Mar 26 2006, 05:37PM Print
Hi, if I do rectify a square wave with a bridge rectifier (yes, it DOES contain a negativ portion) will there be any ringing due to harmonics?
And the rectified voltage will be the same as the square waves amplitude, minus 2 * 0,7V right?
Hazmatt_(The Underdog)
Sun Mar 26 2006, 06:38PM
what exactly are you trying to accomplish? And why would you feed an already D.C. component to a bridge?
Sun Mar 26 2006, 06:39PM
A bridge rectifier will work fine for this.
Marko
Sun Mar 26 2006, 06:55PM
hazmatt, guy said he has a negative portion so bridge rectifier must be used.
Nothing special will ahpen, you will only have better filtered output (depending on quality of square wave) and very small filtering cap should be enough.
Madgyver
Sun Mar 26 2006, 08:38PM
It is actualy used for capacitive positioning detector (neg. Volatge is left, center is 0V and pos. voltage will be right). I know that the circuit will work, as it is nothing new. I just couldn't find any clues on the net if the thing is sensible to harmonics or stuff.
I actually didn't thought that it could freak out, but you never know for sure...
Simon
Tue Mar 28 2006, 02:03AM
It's probably best to consider it like this:
A square wave has huge harmonic content, an ideally rectified one has none. Your rectified square wave will be somewhere in between.
You just won't kill all the buzz of the square wave, that's all that means. Nothing will go crazy.
Madgyver
Tue Mar 28 2006, 01:45PM
Okay, I will consider that. A cap will help as always i suppose?
Simon
Wed Mar 29 2006, 01:34AM
Madgyver wrote ...
Certainly - if it's a problem.
Wed Mar 29 2006, 09:12AM
Adam Horden Registered Member #176 Joined: Tue Feb 14 2006, 09:35PM
You could use a prevission rectifer but these are used mainley for precission work and not used where you need to draw exssesive current from the output.
They are used for rectifying AC sine waves from mV to V range. The diode threshold voltage is cancelled out. They are used in instrementation.
I designed a precission rectifer circuit with two Op-Amps.
Adam
Madgyver
Wed Mar 29 2006, 01:54PM
Yay, thats great. Didn't even know that this exists. As this is for sensory application, the low voltage sensing is a GREAT feature.
THX
