  • Guests: 32
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Need Physics Help!
coillah
Wed Oct 22 2008, 04:01AM Print
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
I need a number check on a photon having 500keV. What is the wavelength?
NM i was using J vs eV
gahahahah terrible mistake....
jpsmith123
Wed Oct 22 2008, 12:51PM
Let's see, the wavelength (in meters) would be h*c/E*q; where h is planck's constant (6.626E-34 J*sec), c = velocity of light in vacuum (2.9979E8 m/sec), E is the energy in ev, and q is the electron charge (1.602E-19 C)...so if E = 500 kev, you end up with:
wavelength (meters) = 1.24E-6/5E5 = 2.48E-12 meters
Edit: Just so you don't get confused by the units, 1 joule of energy is the amount of energy needed to accelerate 1 coulomb of charge through a potential difference of 1 volt...thus coulombs = joules/volt...so to make the dimensions work out, think of "q" as joules per volt of energy rather than electron charge.
G^3
Wed Oct 22 2008, 11:38PM
G^3 Registered Member #97 Joined: Thu Feb 09 2006, 05:40PM
Something I was taught to make these problems easier is that hbar*c=197.33eV*10^-9m or 197.33eVnm and hc=1240eVnm
