  • Guests: 71
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
IGBT driver
Linas
Wed Oct 15 2008, 03:23PM Print
I making big DRSSTC full bridge, with large IGBT (600V 400A pulsed 1KA), so i need IGBT driver with negative shutdown. For it i madded SMPS with 3 different +15 0 -15 output (stabilized with 7815 and 7915). For signal i will use GDT transformer... so i need create diver with 0,5uS delay time, and don't delay turn off... also it will be nice to have Usat protection...
The biggest problem, i can't use UCC's, because voltage between positive and negative is 30V...
so how to make driver ?? neutral
1224084222 1143 FT0 5
And here is my IGBT Link2
does enough+15V at 1KA peak impulse ?? or mayne use +18 0 -18 gate driver voltage ??
teslacoolguy
Wed Oct 15 2008, 03:37PM
can you use a bd139/40 pair?
Wed Oct 15 2008, 05:28PM
Use only one supply (+15V) with two UCCs connected to it, one inverting and one non-inverting, then connect the gate and source between the outputs. This will work as a gate drive fullbridge and allow you to put +15V and -15V on the gate relative to the source.
Linas
Wed Oct 15 2008, 05:55PM
Dr. Kilovolt wrote ...
yes, i think to do same, but i don't know, how to drive two UCC bye using one GDT winding ?? confused
Wed Oct 15 2008, 05:57PM
Linas wrote ...
like I said, use one inverting (UCCx7321) and one non-inverting (UCCx7322) then connect the inputs together and drive from 1 winding. How fast do you need the response time? It would probably be more convenient to use a opto-coupler.
Linas
Wed Oct 15 2008, 07:32PM
Hm i don't like opto-coupler, they aren't stable in such a things... i believe, that GDT don't give errors in DRSSTC diver,..., also, i can't get in my country fast opto-coupler cheesey
Thu Oct 16 2008, 10:11AM
There have been hundreds of threads on this topic since DRSSTCs were invented. Steve Ward and I both have high powered discrete driver designs, and so do a few other forum members, and we all think our own design is best and the others suck wink So start by searching the archives, and looking at Ward's site.
My own driver is here: Link2 it has what you call "negative shutdown" (I think) and isolation by GDT. Anyone who thinks theirs is better, post here smile
Wolfram
Thu Oct 16 2008, 12:19PM
What about driving the bricks directly from a big GDT? Much simpler to implement.
Anders M.
Linas
Thu Oct 16 2008, 12:39PM
i believe, that much simple use independent drivers with semiconductors, it give more functions, and better speed,but stick have two ends cheesey
Dylan
Tue Oct 21 2008, 04:51AM
Dylan Registered Member #1024 Joined: Sun Sept 23 2007, 10:56AM
I have to agree with Anders here.
I currently drive a fullbridge of Toshiba MG200 200A bricks, and am using a discreet GDT driver ( based on the fullbridge in Steve Wards new driver) , with my own two chip logic block.
This descreet GDT driver stage will happily handle 50-60A peak currents.
My GDT is wound using 4core shielded audio cable with the shield as primary and internal conductors as secondaries, on a BIG torroid from Surplus Sales of Nebraska.
This works very well indeed with my main 71Khz secondary, in fact I can drive my 170Khz secondary with no problems.
And really you cant get much simpler than this setup.
Having said that , your 3 channel smps looks great, a work of art! And It would be a shame not to use it cheesey
Pic of my bridge showing GDT:
2898458152 91b7451168 M
Pick of my DRSSTC driver during construction (the top half of the descreet GDT driver is at top right the two D2pak p-ch fets are on the top of the pcb with the N-ch on the bottom side), see Steves new driver for schematics of this section.
2888188619 D8fa019fb6 M
