12v ZVS driver
Avi
Mon Oct 13 2008, 08:58AM
Registered Member #580
Considering these circuits need about 40v to work well, would it be possible to make some modifications to it to operate ALOT better then the default design does on 12v, using only 12v? if so what changes should be made?
Registered Member #95
Using fewer primary turns and mosfets optimized for low voltages is all I can think of.
