  • Guests: 157
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Voltage regulator 6 to 5 Volts
j.azz
Sat Oct 04 2008, 03:27PM Print
j.azz Registered Member #888 Joined: Tue Jul 10 2007, 06:52PM
Does a voltage regulator exist that gives me 5 Volts when provided 6 Volts?
The standard LM7805 I have have a voltage drop of 2 volts so I would at least need 7 volts supply. Are there some with a drop of 1 volt or below?
Bjørn
Sat Oct 04 2008, 03:38PM
Yes, there are many, see here as an example: Link2
The drop depends on different factors like current and temperature. If you only need a limited current at a given temperature a 2 V drop worst case regulator may work fine. It should be specified in the datasheet.
j.azz
Sat Oct 04 2008, 03:51PM
Thank you for the quick answer.
The current needed will be quite low (AVR microcontroller). Plus a few LEDs.
In the datasheet it says voltage drop of 2 volts at 1 amp, so at about 100mA it might work?!
Bjørn
Sat Oct 04 2008, 04:02PM
That is possible, exactly how much lower the drop will be at 100 mA depends on the design of the regulator. My guess is that it will still be a bit higher than 1 V.
If the design is not critical you might not need a regulator at all, run it at 6 V or one or two diodes in series can be all you need.
Lakeowner
Sun Oct 05 2008, 10:06AM
Lakeowner Registered Member #1370 Joined: Mon Mar 03 2008, 09:01AM
switch-mode regulators might be good.
ShawnLG
Sun Oct 05 2008, 04:55PM
As Bjørn says. Diode voltage drops are your cheapist and easyist route.
j.azz
Sun Oct 05 2008, 05:02PM
thanx!
That works for me.
(since no reference voltage needed for i.e. adc)
Sat Oct 11 2008, 11:22AM
Hmm. Well this will work somewhat, the other trick is to use a 78L05 which IIRC works with <1V headroom.
-a
