  • Guests: 73
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
C311C Problems :S
voyagerscout
Fri Oct 03 2008, 11:14AM Print
voyagerscout Registered Member #1696 Joined: Sat Sept 13 2008, 06:01PM
I am building a boost converter, which needs a LM311 chip.
I went to the local electronics shop and the owner told me a c311c is the same thing.
my converter worked, but the c311c chip didnt't
I bought a new one, and build a separate circuit to test them both.
now comes the weird part:
the old c311c chip made the led light up, the new one didn't
so, my question is, does any of you know a easy circuit tot test my comparator?
and what did I do wrong?
the circuit:
1
voyagerscout
Fri Oct 03 2008, 12:48PM
I'm really getting a headache from this problem :S
Fri Oct 03 2008, 03:29PM
Reduce the 15k in series with the potentiometer to ground down to 10k or so. Remember that the negative input has to become slightly less than the positive if you want the LED to turn off. With the correction your circuit should be able to test op-amps.
voyagerscout
Sat Oct 04 2008, 07:38AM
I went back to that electronics store, and the guy gave me 2 new ones, and they both work fine xD
I bought 2 broken ones.....
