  • Guests: 34
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
2Phase servo motor driven by single phase
Coronafix
Thu Oct 02 2008, 02:19AM Print
I have a 3 phase variable transformer with a 2 phase 2 pole servo motor driving the stack.
My question is, does anyone know if this can be wired to run on a single phase?
I took a photo of the diagram on the side, it shows a series and parallel connection.
1222913807 160 FT0 Pict0002
It is currently connected in series. Is this usable at all with single phase?
Thu Oct 02 2008, 09:45AM
Yup, just connect one phase to the line directly, and the other phase via a capacitor to provide a 90' phase shift. To reverse the motor, swap them over. The series and parallel options are presumably to let the motor run off either 120V or 240V line.
It's designed so you can wire it up with a momentary centre-off switch for "increase" and "decrease".
Coronafix
Thu Oct 02 2008, 11:18AM
Thanks heaps Steve for the answer. The motor is rated at 100V so i'm not sure about the series parallel theory being for 120V or 240V, but you would know more. I'll try it in the series mode as that is what it's set at.
I found it strange that it had a 100V motor in it as it came from a battery charging circuit (Telecom I think), and we use 240V here. I will use a step down transformer for it if your theory isn't right. On that train, would a series connection enable 240V connection (theoretically).
I had the momentary switch thing worked out for it as the diagrams all show two switches, so I gathered it was forward and backward.
Any idea what size capacitor I should use for it? or doesn't it matter as long as it's not too small? It is rated at either 1 or 7 watts, the stamping is rough. I think it is 1, but that seems small to me. The shaft on the variable transformer takes no effort to turn though, not like a normal vari xfmer.
Edit. I got it working using a 2.2uF cap, scared to use a higher voltage though. Will use a stepdown transformer with it.
