  • Guests: 29
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Fan Heater Thermostat
Duncan
Mon Sept 29 2008, 03:52PM Print
Duncan Registered Member #524 Joined: Thu Feb 15 2007, 03:28AM
Hi All,
I pulled this thermostat (at least I'm pretty sure that's what it is) from an old fan heater but can't work out how this one works. I understand how the coil type ones work but not this type. The 3 white cylindrical parts look like they're made from some sort of ceramic. Can anyone enlighten me?
1222703433 524 FT0 Thermostat
Mon Sept 29 2008, 04:53PM
It utilizes a bimetal to make a contact when the temperature changes are high enough to make the bimetal bend.
Bimetals are 2 different metals joined together, with different mechanical displacements to temperatures, that way you can make a certain bimetal to bend to one side at a certain temperature.
Duncan
Tue Sept 30 2008, 09:22AM
Ah right ok, so it's pretty similar to the ones that have the bi-metallic strip in a coil configuration.
