  • Guests: 43
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
ISOTOP package
Wed Sept 24 2008, 10:34AM Print
is Pin1 power source and pin4 signal/gate source, or the other way round?
Experimentonomen
Wed Sept 24 2008, 03:04PM
Its like any fet, just that u have a second source connection.
guitardude012
Wed Sept 24 2008, 03:46PM
guitardude012 Registered Member #968 Joined: Fri Aug 24 2007, 04:54PM
Right the two source terminals will probably test as connected on a multimeter.
edit: fixed typo
Wed Sept 24 2008, 04:41PM
guitardude012 wrote ...
Right the two source terminals will probably test as conneted on a multimeter.
I can confirm that.
Wed Sept 24 2008, 07:29PM
Yes, but I thought one is intended for main current path while the other is for connecing to gate driver, or it doesn't matter?
guitardude012
Wed Sept 24 2008, 07:36PM
I don't believe so. The Spec Sheet shows them connected before being used by any other part of the schematic. I believe under low power applications you may leave pin 1 or pin 4 unconnected.
edit:
Wikipedia:
"In general, the MOSFET is a four-terminal device, and in integrated circuits many of the MOSFETs share a body connection, not necessarily connected to the source terminals of all the transistors." Link2
I have looked the document over twice and can't find a reference to either pin 1,4 being the body connection. The spec sheet doesn't lead me to believe either pin is connected to only a subset of the transistor source terminals.
Wed Sept 24 2008, 08:48PM
Try to use a shortsafe power supply and a Ameter and short circuit the pins.
Wed Sept 24 2008, 11:40PM
Either terminal can be used as the power source and kelvin source. Internally its a heavy bus bar type connection that solders down to the die, symmetrical to either tab.
Thu Sept 25 2008, 04:57AM
Steve Ward wrote ...
Thanks Steve
