  • Guests: 39
07/16 Gavin (49)
07/16 Froskoy (33)
07/16 UnHappy1 (59)
stinking hot parts :(
Tue Sept 23 2008, 07:57PM Print
So i made the driver for Jacobs ladder, but I have ran into problems. The KA3525 controller is getting quite hot, even running without any load (GDT unconnected)! Its power draw changes when I change the running frequency.
I had some shorts on the circuit board previously so I'm wondering if this may have damaged the IC. I could replace it but the problem is that its soldered directly to the board and it would be a great PITA to resolder it, and the circuit board would probably lose some solder pads...
With the GDT and FETs connected, the sink on the volt reg. gets VERY hot and the control IC nearly as much (probably heat conduction)...
Other than wasting several watts of power, the driver seems to work normally...
So, it is normal that a SMPS controller IC gets hot even running no-load, or is my part damaged?
Edit: pic
1222199996 152 FT54447 Driver
Edit2: I found another problem, I put in the wrong value of the tuning capacitor, 1/2 of its value. So putting in the right one should cut the f in half, decreasing heating to acceptable level...
Ken M.
Tue Sept 23 2008, 08:51PM
Might wanna doule check your soldering connections, and wiring
Tue Sept 23 2008, 09:07PM
I replaced the tuning cap and things are still hot, but only so much that I can actually hold my finger on the components without getting burned cheesey
I guess the temperature rise is the result of the components stuffed together, on the breadboard they were nicely spaced.
The temp is now acceptable so I think the problem is solved smile
I will post the finished ladder tomorrow if nothing goes boom, I'm really in a hurry as "they" also asked for a demo plasma lightbulb, that will be powered just with the single transistor driver so it should be done quickly. And I must have everything finished tomorrow night cheesey
guitardude012
Tue Sept 23 2008, 11:25PM
guitardude012 Registered Member #968 Joined: Fri Aug 24 2007, 04:54PM
Is a small computer fan an option? smile Should help if W / (cm^3) gets too bad.
Wed Sept 24 2008, 05:56AM
I don't want to include any fans as even a little airflow seems to disturb/ stop the JL arc from rising...
Wed Sept 24 2008, 05:12PM
I tried a '3525 once and it's one output died somehow rendering it useless, so I've stuck with '494s since. In my experience the 494s never dissipate any noticeable power unless they were actually switching some current with the internal drive transistors. Since I assume you're using gate drivers of some kind the smps controller shouldn't be dissipating any power for gate driving. I would consider the heating abnormal.
